Manifold Build Blog
发表于 2021-8-31 22:05:48 | 显示全部楼层 |阅读模式
Another runner tacked up; gotta break it apart and turn it a few degrees. This is the hardest jigsaw puzzle I've ever done.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Nice looking ram horns. Nice job!how are you cutting the tubes?
Reply:Originally Posted by GambleAnother runner tacked up; gotta break it apart and turn it a few degrees. This is the hardest jigsaw puzzle I've ever done.
Reply:GambleAmbitious work . . .Keep us posted: on the 'gas dams',and 'port and polish' sequences . . .Opus
Reply:No need to polish when it carbons over 5 minutes after The engine running
Reply:Originally Posted by MikeGyverYou aren't even at the "hard" part yet. Every single one of those joints will shrink the length 1/16" and everything will fit a little bit different and the flange will pull out from being flat. Also it's best if you leave a .045" or so root gap, you can't really get full pen with them butted up unless you reallllly burn in hot (which is not a good thing to do here lol).My suggestion is to weld up the runners then weld them to the merge with the head flange tacked on, then if the head flange warps you can remove it and adjust the runners/gap as necessary to get the thing flat. It would even be a good idea to leave the tube that welds to the head flange 1/4" long and trim as a final step before making those welds. Make sure you bolt the head flange down to something extremely stiff. It's most likely going to curve regardless of what you do so just plan on needing to belt sander/machine it flat afterwards.
Reply:Fun stuff! Good luck with it. Lookin good so far!12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Have you figured out a way to flood the inside of the tubes with Argon while welding? If you don't do that the inside of the welds will be as rough as corn cobs... definitely will not help your exhaust flow.
Reply:Originally Posted by TIGguyHave you figured out a way to flood the inside of the tubes with Argon while welding? If you don't do that the inside of the welds will be as rough as corn cobs... definitely will not help your exhaust flow.
Reply:Lol^^ I figured you knew lol. Nice tube fixture you boughtLast edited by motolife313; 04-22-2015 at 12:56 AM.
GMT+8, 2026-1-3 01:39 , Processed in 0.070965 second(s), 18 queries .
