Roughed:
发表于 2021-8-31 22:05:46 | 显示全部楼层 |阅读模式
Hood on my G-258 roughed. I should have taken before photos but once into a job I really don't stop. This thing had a tree fall on it in the 70's according to former owner and it had literally 3/4" filler in it through about 3/4 of the hood. A mushroom bit on an air hammer and an 8" 40 grit "D" weight disc on a "mud hogg" to rip the filler and paint off, and about three hours beat, heat, shrink, etc. and it's just about 1/8" low now through the middle. I may finish it out tomorrow. Take note of the drilled but not welded shut holes for some dent puller action. Also the rip that was never repaired/welded up after knocking the metal back into semi rough shape. Almost looks like "Mickey Mouse" paid me a visit too. Attached ImagesSlobPurveyor of intimate unparalleled knowledge of nothing about everything.Oh yeah, also an unabashed internet "Troll" too.....
Reply:Wow.  That's a lot of work and is looking good.  Would have been nice to have seen a before shot but I've seen an SA200 that had a tree fall on it and have a good idea what it must have looked like. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks Duane. Didn't have anything to do so decided to work with this. I think the hood lost about 10 pounds when stripped. I'll pull it again and the fuel tank to straighten the filler neck which is laid over a bit. With the hood straight, it doesn't align correctly in the protrusion hole. It's near five foot span is pretty soft with no under bracing although it's 18 gauge material.SlobPurveyor of intimate unparalleled knowledge of nothing about everything.Oh yeah, also an unabashed internet "Troll" too.....
GMT+8, 2026-1-3 01:39 , Processed in 0.097225 second(s), 18 queries .
