Onan 225g / Bobcat engine
发表于 2021-8-31 22:05:44 | 显示全部楼层 |阅读模式
I have a 16hp onan gas motor currently sitting in pieces looking for a new home.  The engine broke a connecting rod and punched a hole in the block into the area under the valve covers, and in the process scored the crankshaft in one spot, but it could be repaired and ground undersize.  It is the old style crankshaft with the threaded end that screws into the generator rotor.So other than that pm me if you are looking for parts.Still available is:Engine block (has a hole)Crankshaft (needs repair)CamshaftStarterFlywheel and chargerAirbox and filterCarburetorPlastic fan shroud / guardCylinder headsExhaust mufflerNew Spark plugs leads and new spark plugsOil filter, bracket and oil sensor1 old piston and connecting rodHeat shieldsIntake and exhaust valvesEverything is shipped from Winnipeg, Manitoba, Canada.
Reply:The threaded crank is actually the new style rather than the old.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-3 01:39 , Processed in 0.103566 second(s), 18 queries .
