Lincoln Mobiflex 200-M Fume Extractor $2000
发表于 2021-8-31 22:05:44 | 显示全部楼层 |阅读模式
One Lincoln Electric Mobiflex 200-M with LFA 3.1 extension arm, it is like new in condition with limited use, good filter, and works great.Runs on 110v, simply plug it into the wall, or the auxiliary outlet on your welder.We bought this for our fabrication shop and shortly after moved facilities to a location with a fume extraction system built into the building. Located In Cedar Rapids, IAWill ship to your location at your cost.From the Lincoln Electric website:Generous airflow - 735 CFM with LFA 3.1 extraction arm.Front casters and rear wheels - provide mobility.Low noise operation - 69 dBA.Internal spark arrestor - also functions as a pre-filter for larger-sized particulate.Cellulose filterOptimal motion and reach for work area Filter status indicator - visual guide to remaining filter life.Large filter capacity - 538 ft¹ (50 m¹)
GMT+8, 2026-1-3 01:21 , Processed in 0.095743 second(s), 18 queries .
