WTB steel rings
发表于 2021-8-31 22:05:44 | 显示全部楼层 |阅读模式
Anybody know were I can buy 2 and 4 inch dia steel rings 1/4 round?.Last edited by Skeeter; 06-16-2012 at 09:53 PM.Reason: forgot to post as want to buy
Reply:Buy yourself a ring roller, and make them yourself.  Might be cheaper, unless your ordering hundreds of them.
Reply:For now I only need 2 dozen of each size, so I can't see buying a roller right now.
Reply:Kings Architecturial. Pretty good prices and fast shipping.
Reply:Ive rolled thousands of them on my lathe. Just set up a piece of pipe smaller than the inside diameter between the chuck and the tail-stock about 3 ft long.  weld a little L shaped chunk of plate to catch the end of the twenty ft. long round bar. wear gloves. and turn the lath on slow. The lath will roll the rod up on the piece of pipe like a spring. when you get close to the end shut the lath off.  The spring shape will unwind a small amount and allow you to take it off the pipe . Then you just feed it into your cutoff saw and little round circles will fall off one after the other, all the same size.  Mac.
GMT+8, 2026-1-3 01:47 , Processed in 0.082187 second(s), 18 queries .
