Have an esab caddymig 160i im looking to sell. Machine is basically brand new has only been used once and that was when I got it to make sure everything works on it and haven't touched it since. New they retail for over $700 so saving you two hundred dollars on a brand new machine. Included with it is spare tips and nozzles and a spool of lincoln .023 mig wire and the free welding helmet that came with the machine. No issues at all with the machine just thought I'd have more use for it then I did when I purchased it and ended up not being the case and has just been sitting on the shelf and needing a tig so, looking to replace this machine with a miller multimatic 200. Will post pics of it later today.Millermatic 212 AutosetSyncrowave 180SDEsab CaddyMig c160i Lincoln WeldPak 100
Reply:Millermatic 212 AutosetSyncrowave 180SDEsab CaddyMig c160i Lincoln WeldPak 100
Reply:Regulator and gas line are included with it, I also still have all the manuals and the original box for it and you can have the esab welding helmet that came with the machine! There isn't even 10 minutes of use on this machine! I took it out the box assembled it struck one arc with it to do a short weld to make sure the welder worked and have not touched this machine since then.Last edited by BB70Chevelle; 05-10-2012 at 06:30 AM.Millermatic 212 AutosetSyncrowave 180SDEsab CaddyMig c160i Lincoln WeldPak 100
Reply:I really like ESAB products in general, but this unit seems limited in its capabilities, given that it is a 230v/160 amp machine, and it can only weld up to 5/32 (4mm) thickness. Any chance you can come down some on your price?Miller Multimatic 255 |
