Wiring help
发表于 2021-8-31 22:05:42 | 显示全部楼层 |阅读模式
I have a 2050 plasma cutter with a hand torch. I recently picked up a Hypertherm machine torch. I see the pin outs are a little different. can the Hypertherm be used on the Miller, what would I change? Thanks.Low speed, high drag............but heavily armed!
Reply:Maybe ask Jim from Hypertherm at this site.http://groups.yahoo.com/group/plasma...yguid=82702294
Reply:If the amperage and number of poles (blades) are the same, then you might be able to use the same plug. For example, there are more than one style of 50A 4-wire plugs.If these are different amperage (you should be able to tell by the wire gauge), or a different number of poles, then it gets more complicated.Starting at p. 16 of this document is a diagram of the plug/receptacle types. Identify which has which and post back if you still have questions.http://www.cooperwiringdevices.com/c..._REFERENCE.pdfFor example, my welder is 50A with 3 conductors, so I wired it with a 5-50.
GMT+8, 2026-1-3 01:20 , Processed in 0.107098 second(s), 18 queries .
