anybody out there using the trigger-select feature on the 70DX feeder? I use it a lot but every now and then it stops working. Not a huge problem cause all I have to do to fix it is go the sub-menu where you switch it on or of and go right back out and it works again. What I'm wondering is, does anyone else have this problem, and is there anything that seems to make it happen? |
