Running a new inverter tig from an older engine drive.
发表于 2021-8-31 22:05:40 | 显示全部楼层 |阅读模式
I was wondering if this would work. A couple of concerns/questions. Welders in question:  Lincoln Weldanpower AC/DC 225 with 6K watt 26amp generator and Lincoln square wave 200 tig. The tig input specs are: 230V 22 amp @ 200 amp output. Question 1: is this generator sufficient?  I understand 22 is less than 26 but it's close. Question 2: Does this generate "clean power" (I forget the technical term, harmonic distortion maybe).  I read somewhere that newer tig machines require clean power because of the sensitive electronics.  Thoughts?  Concerns?  Any input is appreciated. Thanks guys.Miller Bobcat 225AHP AlphaTig 200X
Reply:That should work. The power created by a generator is clean until something such as a ballast transformer messes with the wave form on that line.I run my inverter plasma cutter on generator power all the time.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
GMT+8, 2026-1-3 03:16 , Processed in 0.097041 second(s), 18 queries .
