What i get called in to do on a Sunday.
发表于 2021-8-31 22:05:39 | 显示全部楼层 |阅读模式
The machine is called a decoiler. Basically a 100 thousand lb coil of roughly 1/8" steel goes on a mandrel and it unwinds it into a straightener. The pressure is more or less 1000psi. It blew the seal out of the rear cap of the hydraulic cylinder on the planetary gear set. Did not have an o ring so had to make and glue one out of 3/8" cord. Also found this lovely filter. The nuts are 28mm to give you a size reference. Sent from my SM-G920P using Tapatalk
Reply:COOL !!!   As for Sunday, that's why you get the big money !!!
Reply:So that is about a 8 to 10 inch bore on that cylinder? Nothing like hydraulics on sunday.
Reply:Originally Posted by MrLeadManSo that is about a 8 to 10 inch bore on that cylinder? Nothing like hydraulics on sunday.
Reply:filter missed it's 3 month 3 thousand mile service?
Reply:Oil, my favorite.
Reply:Originally Posted by Michael rayfilter missed it's 3 month 3 thousand mile service?
Reply:Originally Posted by TigMonsterBy a day or twoSent from my SM-G920P using Tapatalk
Reply:If you guys like this sort of thing i can post up some of my bigger jobs during the week.Sent from my SM-G920P using Tapatalk
Reply:Post away, somebody has to keep the world running.
GMT+8, 2026-1-3 03:40 , Processed in 0.230006 second(s), 18 queries .
