Lincwelder Nameplate
发表于 2021-8-31 22:05:37 | 显示全部楼层 |阅读模式
I found a brand new name plate today in the shop "tool room". Its for a LINCWELDER 250. If you need it let me know, you can have it! I cant bring myself to toss it, I am sure someone out there can use it. Attached ImagesYou have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Yea, I cant bring myself to throw away anything.You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:I just purchased a Linc Welder MK250 today.  I would be interested in the nameplate if you are still looking for a home for it.
Reply:Welcome, Cutter - Whatchas' plan on doing with the coffee grinder?They sure are a smooooth welder, with great controls.Good Luck
Reply:Thanks, denrep.  I have the gasoline counterpart to this welder (1954 LincWelder 250AS with a Wisconsin 4-cylinder) and have been looking for an electric motor generator for some time.  The MK250 is similar to the ones I used at the power plant I worked at and was one of my favorite stick welders.
GMT+8, 2026-1-3 03:32 , Processed in 0.100401 second(s), 18 queries .
