Pro core 100 slow feed
发表于 2021-8-31 22:05:36 | 显示全部楼层 |阅读模式
Hi all,Sorry if this question has been posted, I couldn't find an answer.  Been welding with the pro core 100 for 4 years.  Never a problem with it till today.  The feed roller is going it's correct speed.  But once in the hose a foot or two, it slows down considerably.  Is the hose dirty?  Something wrong with the gun?  Ive looked ay everything else.  I appreciate your time.JasonJason
Reply:i guess needs new liner -- 4 yrs on a liner got crud build up inside or a kink pull out a look at itidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:New liner time.
Reply:Thanks for the replies.  Turns out it was a bad spool of wire that was , i guess, wound wrong on the spool at the factory.Jason
Reply:Rare problem. I have seen the wire get crossed and knotted and stop the wire from feeding.
GMT+8, 2026-1-3 03:16 , Processed in 0.069171 second(s), 18 queries .
