12VS or 8VS?
发表于 2021-8-31 22:05:31 | 显示全部楼层 |阅读模式
I really need a new wire feeder.. I want a 12vs, but they are so heavy, and pricey. I have a 8vs for $500, at half the weight and 1/3 the price of a 12vs, but it greatly limits my options when shopping for filler metals. Its going on an XMT 350 for the most part. How hard is it to put a Lincoln feeder on a Miller 14 pin connection? The Red-D-Arc sale ends soon, and I'm hoping to jump on it.Constant Current Weldor.
Reply:Vs feeders can go on any power source.....If it's a remote feeder, I'm pretty sure they aren't compatable thru out the different brands (red and blue)8vs will be just fine if your only running 8" spools.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Why not look at an  ln_25 33lb spools save on wire costsMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I am looking at a Suitcase or Lincoln benchtop. I do not like ln-25 or the guns that go with them. I don't have any problem with 8" spools, but they are hard to come by in some of the applications I use, most notably a D1.8 qualified self shielding wire. Im not sure what it would take to put a Lincoln benchtop on a XMT?Last edited by Davidbrown; 03-29-2015 at 05:30 PM.Constant Current Weldor.
Reply:Brand X has a Lincoln machine on his Shopmate.You'll have to make an adapter cord to pick up 115 from your machine, and use a relay between the miller machine and Lincoln feeder since Lincoln machines use a nonenergized contactor closure.I'm sure Scott can tell you how he hooked his up.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:8VS or 12VS are voltage sensing feeders and don't use a 14 pin connection to the power source. Only difference between an 8 and a 12 is size of the spool they can take. Both will run off any DC power source.
Reply:The 12" spool capacity is better to have because some wire only comes in 12 " spoolsand you can always put an 8" spool in it but not the other way aroundIf you buy a feeder and don't like the gun there are all kinds of guns that can be adapted to your feeder from all the popular companiesBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2026-1-3 03:32 , Processed in 0.225574 second(s), 18 queries .
