Haul Truck Bed Rebuild
发表于 2021-8-31 22:05:28 | 显示全部楼层 |阅读模式
These pictures are from rebuilding several haul truck beds at the open pit copper mine just out side Ely, Nevada.   There's a good solid week of 6, 12's at the start just gouging all the old liner plates out and damaged structural components off before cutting the center of the floor out to be able to replace the broken frame work bolsters underneath.The less pleasant part was gouging this grid work of heavy flat bar off the tail board area.The old liner plates had a lot of stress in them from being work hardened and it was best to back step down the weld when gouging them off to let them pop loose in 1 to 2 foot increments so you didn't end up getting slapped by one when it jumped free.  The new center bolsters welded in place ready for a new section of floor plate to go in.The new floor plate just about welded in.
Reply:New floor liner plates going in.Lots of dog and wedging to get things in tight for welding.       The new clad tailboard pieces tacked in ready for welding out.
Reply:Clad tailboard plates welded out.As we'd get one done they'd bring another haul truck that needed it's bed rebuilt up to where we were working and swap out the beds.
Reply:Awesome!
Reply:Your no small time operator, Looks epic!!!Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:56; great pictures. re-building those heavy haul bodies looks like a never ending process. what rods/wire are you using to weld those cladded plates?i.u.o.e. # 15queens, ny and sunny fla
Reply:Time consuming project. Are you using T1 AR plate?  And what wire are you using?
Reply:Man, this is some awesome $hit!!!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2026-1-3 03:14 , Processed in 0.095480 second(s), 18 queries .
