Guess again...
发表于 2021-8-31 22:05:26 | 显示全部楼层 |阅读模式
I know it's been a while... So moving along, what is this?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Some sort of gear thing...I think.
Reply:Something to clean the inside of a pipe, possibly cast iron drain pipe
Reply:Originally Posted by EloewenSomething to clean the inside of a pipe, possibly cast iron drain pipe
Reply:A pipe knurler?Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Planetary gear reduction drive unit ........zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Metal
Reply:some kind of granulator to make raw material flow down a chute... whatever,  it's amazing all that knowledge we are loosing
Reply:I'm with zap planetary gear reduction. Curious what it drove though. Regards-Carlo
Reply:A D&C tool for abortions, nice job cleaning it up. Too big for elephants, maybe for whales? Seriously, I'd guess a pipe cleaner, but the universal joint would cause it to bind.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:I'd say it's for cleaning or knurnling the inside of a pipe, the cone "gears" look like they would keep it centered and the side gears look like they are closer in design to a star wheel dresser than a gear, looks like they are multiple pieces that would knock scale loose.
Reply:You guys were just about spot-on. I have a friend that works at a local paper mill and he snagged it from a pile of junk. He believes that they used to use it on their old steam lines. You mount it on a shaft and rotate it down the pipe to knock off any buildup. I never measured it, but I bet it would work on 3 1/2" thru 5" pipe because the arms with the tapered gears can swing outwards for larger diameters.Common sense in an uncommon degree is what the world calls wisdom.
Reply:so , it's a pig, then.
Reply:Yea it's a Wilson tube cleaner for removing scale on the inside of boiler tubes. We usually ran our's from a water turbine and had it attached to reinforced hose @ 175 psi water . I have a lot of hours behind one of those .Put a lot of money in the the bank doing it to .
Reply:Originally Posted by TimmyTIGso , it's a pig, then.
Reply:gxbxc made bacon with it...so a pig it is.certainly was not a planetary,bc   absence of the "sun" central gear in the middle of orbiting gears.
GMT+8, 2026-1-3 03:14 , Processed in 0.096601 second(s), 18 queries .
