Few pics of a gradall i,m in the process of repairing. Attached Images
Reply:Man that's a lot of grease. Does it all burn up on you when you're repairing, or is it far enough away that the steel it's on does not get hot? I just replaced the pancake filters I wear under my hood after smoking grease from deep inside hot rolled square tube (outside ground, sanded bare) turned them gray.
Reply:Few more pics.Had them pull cab glass to repair cab side.Lucky on had crack not piece torn out. Attached ImagesLast edited by admswelding; 05-05-2015 at 09:11 PM.
Reply:Nice fixBacked my CATMA over your CARMA oops clusmy me What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:GEEZ! so where/ why did the piece thats missing leave?bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Notice the small shims behind the ring.The back one broke free and fell out ,allowing some flex which started the crack and lead to the break and piece coming out.The machine was dissaembled and we pulled the the boom forward off the rollers to gain access.QUOTE=92dlxman;5835071]GEEZ! so where/ why did the piece thats missing leave?[/QUOTE]Last edited by admswelding; 05-06-2015 at 04:19 AM.
Reply:The booms on Gradalls telescope and also rotate 360 degrees...The boom structure is triangular ...It puts a lot of stress on those partsBacked my CATMA over your CARMA oops clusmy me What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:OTE=killdozerd11;5835701]The booms on Gradalls telescope and also rotate 360 degrees...The boom structure is triangular ...It puts a lot of stress on those parts[/QUOTE]Yup I been told this is pretty Tookcommon.First I seen,but mechanic who took apart has seen before he said. |
