Pullup station.
发表于 2021-8-31 22:05:26 | 显示全部楼层 |阅读模式
Made this for a friend. Was $200 in materials vs buying the production one for $600.All 2" tube. Used receiver tube to make the bar ride on the rails so it's adjustable.Attachment 1095591Attachment 1095601Attachment 1095611Attachment 1095621Attachment 1095631www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Attachment 1095641Attachment 1095651Attachment 1095661Attachment 1095671www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Attachment 1095681Attachment 1095691www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Nice job...
Reply:Nice work man! You gona mix up some concrete and layed out a nice square so it don't Rock around? You could add a bar for dips too. How's that little lathe work for you?
Reply:Originally Posted by motolife313Nice work man! You gona mix up some concrete and layed out a nice square so it don't Rock around? You could add a bar for dips too. How's that little lathe work for you?
Reply:What happen to the gussets?i wish I had a lathe! I take stuff to my machinist about once a week.did you see the adjustable pull-up bar I made couple weeks back?you already have a dip bar if you can lower the top bar?Last edited by motolife313; 05-02-2015 at 12:48 PM.
Reply:nice work. that station probably won't be very stable once the ground get's a little soggy.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docweldernice work. that station probably won't be very stable once the ground get's a little soggy.
Reply:Did you test it out a bunch of times before you sent it off to your friend?SA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:Originally Posted by BlockerDid you test it out a bunch of times before you sent it off to your friend?
Reply:Originally Posted by motolife313He mostly likely had 14 inch biceps before he made it now he has 16's lol
Reply:Lol I don't know you that good.
GMT+8, 2026-1-3 03:13 , Processed in 0.097676 second(s), 18 queries .
