Buffalo 21 drill press
发表于 2021-8-31 22:05:25 | 显示全部楼层 |阅读模式
If you have a Buffalo 21 drill press and need some parts send me a PM. The motor is bad and the  back gear is shot but the rest of machine works fine. The press will work pretty good as it sets but if you engage the drive the motor will stall and come to a stop. Just not worth it to me to spend any money on getting it running like it should.The motor could be replaced but the back gear is very exspensive... Attached ImagesLast edited by Gearhead; 06-25-2012 at 10:12 PM.Southbend 13" latheBuffalo 18Warner Swasey #3 Turret latheMiller 180Miller Dialarc Miller Diversion 165
GMT+8, 2026-1-3 03:13 , Processed in 0.114547 second(s), 18 queries .
