WTB: Some Ni55 tig fill rod (couple sticks)
发表于 2021-8-31 22:05:25 | 显示全部楼层 |阅读模式
Don't need much. Welding a flapper shut on an internal wastegate setup on a cast iron turbine housing. Anyone have some they'd ship?Hobart EZ-Tig newbie.
Reply:I have some "Weld Cote" brand Nickel 55 stick electrode in 3/32" diameter.  Should work fine for TIG, if you manually removed the flux covering.http://www.weldcotemetals.com/dataFi...s/techNi55.pdfThey are 14" long.  Probably would ship easily if I folded them in half, then I could mail them in an envelope.I would be sending from 98008.  IM me if you're interested.
Reply:sent you a pm!Hobart EZ-Tig newbie.
GMT+8, 2026-1-3 03:21 , Processed in 0.071143 second(s), 18 queries .
