rig truck for sale
发表于 2021-8-31 22:05:24 | 显示全部楼层 |阅读模式
im selling my rig truck, i havent activly used it since 2003, i built this one in 2001 and replaced the classic 3d with a new sa 200 pipeliner diesel. it has the kubota engine the truck has been indoors since 2005, started every other week and used occasionally in the plant i work in. the welding machine has 240 total hours on it, and has had 3 oil changes, it has the remote which has never been pluged in,100' of pos. and neg. each lead with an extra 50 on quick connects, and is mounted on a roll up fold down mount. the bed has everything on a frame which can be pulled in less then 2 hours, has 2.5 gal water jug, oxy acc. torch with 100' of hose, 1- 4 to 2 1- 8 to 4 1- 12 to 8 mathey deerman beveling machines and a short and a long machine torch. more storage then you need with a large tool box on rear 2 small boxes under large,  room inbetween for 6 fold up jackstands and a ridged tri stand and a real slick way to lock the tailgatei will sell whats in the bed seperatethe truck, 1970 chev. it needs paint and a little tlc in the cab, mechanicly its excellent. all listed below has less then 20,000 miles on it. front end rebuilt form bushings to ball joints, rear end complete rebuild in cluding driveline diff., and leafs, engine 427 big block tall deck industrial engine, gobs of torqe and runs on low grade gas, great mpg also i averaged 14 and didnt waste any time when i was going somewhere. transmission was bought new, it is a new veture 4500 5 speed the never modle which doesnt have the 5th gear problem, 2200 rpms is 75mph. the tires and wheels have less then 5 miles on them.  $13,000.00 for it, the suggested retail on the welder alone is over $16,000.00.  if your good at pipe and willing to hussle and travel you can make  $5,000.00 a week with this truck.  i have more pictures that i can e mail if needed. it took so long to load this one i didnt think it would let me put any more on. im in utah p m if interested or want to talk on the phone Attached Images
Reply:where are you located?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by Dualiewhere are you located?
Reply:Originally Posted by luckynorthern utah
Reply:Originally Posted by W123BenzUintah basin?
Reply:Hey bud would you be interested in selling the machine seperate?
Reply:Originally Posted by CoaltrainHey bud would you be interested in selling the machine seperate?
Reply:Would you sell the bevel machine seperate?
GMT+8, 2026-1-3 03:05 , Processed in 0.120654 second(s), 18 queries .
