Miller Thunderbolt as a Tig source?
发表于 2021-8-31 22:05:20 | 显示全部楼层 |阅读模式
Anyone ever used a Miller AC/DC thunderbolt as a tig source?I have heard some conflicting reports. This would be for a home use type set up.Thoughts?Thanks, Doc.Some of the things I do would cause a person to get hurt, expelled, arrested, or possibly deported. To put it another way, don't try this at home.Look at the stars whenever your can. That light travelled a long way to get here, dont let it go to waste on some patch of asphalt.
Reply:It all depends on how good a TIG machine you expect to end up with.  You can add a HF unit and get it to do AC TIG, but you won't be able to set it up with a foot pedal, so your control is limited.  Same for DC.  IMHO, you'd be a lot better off just spending your $$ on a rig designed for what you want.Hank
GMT+8, 2026-1-3 03:14 , Processed in 0.107251 second(s), 18 queries .
