spectrum 375 and psi???
发表于 2021-8-31 22:05:20 | 显示全部楼层 |阅读模式
I recently got a 375 and am starting to use it alot, however i am having issues with quality cuts and slag.  The psi is set at millers req around 25-30 psi, however when i turn up the psi to around 50-70 it seams to work alot better.  I have used a thermodyne and it set it psi at 75.  Will uping the psi on the mikker hurt it?  also what are your settings on this?  I cut mild steel around 1/8 to 1/4.Thanksshawn
Reply:Originally Posted by dapozerI recently got a 375 and am starting to use it alot, however i am having issues with quality cuts and slag.  The psi is set at millers req around 25-30 psi, however when i turn up the psi to around 50-70 it seams to work alot better.  I have used a thermodyne and it set it psi at 75.  Will uping the psi on the mikker hurt it?  also what are your settings on this?  I cut mild steel around 1/8 to 1/4.Thanksshawn
GMT+8, 2026-1-3 03:04 , Processed in 0.114970 second(s), 18 queries .
