MM 185 or MM 175 ?
发表于 2021-8-31 22:05:19 | 显示全部楼层 |阅读模式
Hello,  I have a brand spanking new Millermatic 175 that I purchased to do bodywork and light fabrication.  I have the chance to trade it for a nearly new Millermatic 185.  What do you think ?  I like the 60% duty cycle of the 185, and portability isn’t an issue. Thanks for the input.
Reply:I run both units. Based on performance alone, I wouldn t hesitate for moment to trade a MM 175 for a MM 185. The 185 is the better unit. With arc dialed in properly, which doesn t necessarily mean the doorchart setting, the 185 has an excellent short circuit transfer arc on .120 (1/8") wall tube. The resulting weld is basically spatter free  .
GMT+8, 2026-1-3 03:13 , Processed in 0.408797 second(s), 18 queries .
