MM-175 wire speed tracking?
发表于 2021-8-31 22:05:19 | 显示全部楼层 |阅读模式
Anyone know if there's a way to disable the wire speed tracking on a MM-175?I'm pretty crafty with electronics so if there is something you can do to the board it would be well within my abilities..
Reply:Why bother, set the heat to what you want and then adjust the wire speed for what works....
GMT+8, 2026-1-3 03:14 , Processed in 0.099522 second(s), 18 queries .
