dewalt battery welder pack???
发表于 2021-8-31 22:05:15 | 显示全部楼层 |阅读模式
So i was checking out the dewalt battery powered  welder. Im wondering if one could use the power supply and use it on a inverter welder like maxstar? The price 3k plus ouch! But if i could purchase the power pack and use it on my current welders it may be something im interested in. Has anyone looked into this idea?  Do other companies make power packs for welders. The salsman stated one can weld 4hours on 100amps with the dewalt setup. Any info or input would appreciated
Reply:Maybe a dumb thought but why not put the three grand toward a engine driven machine. Mike
Reply:Size is an issue my friend. Running a inverter generator is fine as well. Though the thought of cordless powerd welder is pretty cool. And could be handy
Reply:I find the 4 hour welding time really hard to believe.The only specs they list on their website is HYBRID duty cycle- which is when the machine is plugged into 120v AC power.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I bet you don't get more than 20minutes at full power with they welder. ..Sent from my SCH-I545 using TapatalkTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:http://weldingweb.com/vbb/showthread.php...der&highlight=Don't waste your money on that dewalt. When the battery goes dead since its a dewalt you know a new battery alone will cost almost almost as much as the new machine did.My welder power inverter could be reproduced with AGM lead acid batteries for around $1,000. If you used two group 31M batteries you could power a 2,000w inverter to power a welder for 10 to 20 minutes.Last edited by mad welder 4; 06-01-2016 at 07:46 PM.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:That Dewalt welder is actually made by Fronius and they have it under the model name the AccuPocket 150  if you were getting one i'd get the Fronius brand not only so people wont hate because its a Dewalt but because of the warranty issues it may have.
Reply:Originally Posted by EvilBunnyThat Dewalt welder is actually made by Fronius and they have it under the model name the AccuPocket 150  if you were getting one i'd get the Fronius brand not only so people wont hate because its a Dewalt but because of the warranty issues it may have.
Reply:$3000 is a waste of money.I built my 13.2v 60ah LiFePO4 diesel truck starting power pack for around $1,000 and added a $364, 2,000 watt samlex pure sine inverter.Mine does the same thing, it can power my 2,000 watt inverter for about 15 minutes and can be fast charged in well under an hour.If you took $3000, you could build a better one and have money left over.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:I always find it funny when people say something is a waste of money because they can "build" it cheaper. You can build yourself a car cheaper than buying a new one too. You can build your own house cheaper than buying one. You can raise your own cow for cheaper steaks than buying from the grocery store. So I guess all that is a waste of money buying too.... Not everyone has the same means or know-how.
Reply:Its batteries and a power inverter.It is so simple I don't know how some one could screw that up.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Originally Posted by mad welder 4$3000 is a waste of money.I built my 13.2v 60ah LiFePO4 diesel truck starting power pack for around $1,000 and added a $364, 2,000 watt samlex pure sine inverter.Mine does the same thing, it can power my 2,000 watt inverter for about 15 minutes and can be fast charged in well under an hour.If you took $3000, you could build a better one and have money left over.
Reply:Remember 2 batteries and a pair of jumper cables can get you somewhere!  Forney C5 Arc WelderLincoln Idealarc 250-250 Ac/Dc Arc WelderMiller Bobcat 225g PlusLincoln PowerMig 200Forney O/A Rig
Reply:Originally Posted by All positions Im wondering if one could use the power supply and use it on a inverter welder like maxstar?
Reply:and 2 of those batteries will add up to 150lbs to hump up the job site. Not zackly portable. Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Yeah that is true. I use one to power a pure sine inverter and I think it weighs 70 to 75 pounds.My lithium pack and 2000 watt samlex pure sine inverter weighs around 50 pounds total. I have only ever attempted to use it with my mig. I think with my transformer based tig it would only run 60 or 70 amps max. How portable does it need to be?old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Originally Posted by mad welder 4Yeah that is true. I use one to power a pure sine inverter and I think it weighs 70 to 75 pounds.My lithium pack and 2000 watt samlex pure sine inverter weighs around 50 pounds total. I have only ever attempted to use it with my mig. I think with my transformer based tig it would only run 60 or 70 amps max. How portable does it need to be?
Reply:Only 25lb?Something seems a little fishy about that.Let's say the welding power source is like an inverter, it's going to have to weigh 10 to 15 pounds it's self then the battery, let's say it is 15 pounds of lithium batteries. That is only going to hold about 0.9 kwh, with about 0.6 or 0.7 useable. The only way you could tig weld for even close to an hour is if you were using running less than 50 amps. Probably well under 50 amps.Last edited by mad welder 4; 06-02-2016 at 09:18 PM.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Originally Posted by mad welder 4Only 25lb?Something seems a little fishy about that.Let's say the power source is like an inverter, it's going to have to weigh 10 to 15 pounds it's self then the power supply, let's say it is 15 pounds of lithium batteries. That is only going to hold about 0.9 kwh, with about 0.6 or 0.7 useable. The only way you could tig weld for even close to an hour is if you were using running less than 50 amps. Probably well under 50 amps.
Reply:Alright 17 minutes at 150amps seems possible. The first post said something about welding 150 amps for 4 hours.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Originally Posted by mad welder 4Alright 17 minutes at 150amps seems possible. The first post said something about welding 150 amps for 4 hours.
Reply:Originally Posted by EvilBunnyA fully charged battery is enough to weld up to six 3.25 mm (0.13”). electrodes or up to eighteen 2.5 mm (0.1”)ones. Not much at all.  ( for TIG  One battery charge is enough for up to 17 minutes of continuous operation at full power (150 A) and the device is fully operational again after approx. 30 minutes of rapid charging. )    For the record the info is straight off the makers website.
GMT+8, 2026-1-3 03:22 , Processed in 0.101303 second(s), 18 queries .
