PQR requirement on weldabale primed part
发表于 2021-8-31 22:05:13 | 显示全部楼层 |阅读模式
Hi,Can anyone help me out in below question.A part which is coated with weldable primer requires a new PQR to be qualified or not? Note: The existing PQR was qualified on the raw plateAnticipating your valuable in put.Thank you, EP
Reply:Wouldn't guarantee I'd be able to answer the question but, which code are we talking about?
Reply:I think you do need to re-qualify the PQR, and detail the product and application. Just about every spec requires some form of cleaning to bare metal. Welding through primer is an essential variable to cleaning requirement IMO.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2026-1-3 03:05 , Processed in 0.106225 second(s), 18 queries .
