Home Depot aluminum tubing.....4043? 6061??
发表于 2021-8-31 22:05:12 | 显示全部楼层 |阅读模式
Anyone know what Home Depots aluminum tubing is? I got some to weld up a project and I'd like to get some filler to match. Thanks
Reply:I recently tried to find out myself.  Not the tube specifically, but Home Depot aluminum (and other "big box stores' " aluminum).  I even checked out the manufacturer (importer?) and still came up empty.  Probably 6061 is all I came up with, but nothing definitive.What is the project, anything critical?
Reply:Lots of aluminum material sold at big box stores like Blowe's and Home Cheapo is anodized. So check that before you buy anything. If it is, it is almost certainly 6061. Not certain, but probable. That said, it should be labeled? I really wouldn't know, I use reputable metal suppliers exclusively.You don't need to buy filler metal of the same alloy if you don't want to. There are a handful of common filler metal types that will work well with the most commonly found aluminum alloys.
Reply:Originally Posted by Hillbilly WelderLots of aluminum material sold at big box stores like Blowe's and Home Cheapo is anodized. So check that before you buy anything. If it is, it is almost certainly 6061. Not certain, but probable. That said, it should be labeled? I really wouldn't know, I use reputable metal suppliers exclusively.You don't need to buy filler metal of the same alloy if you don't want to. There are a handful of common filler metal types that will work well with the most commonly found aluminum alloys.
Reply:Well, 6061 is far and away the most commonly used alloy when it comes to extrusions like that. That is my best guess, having no other knowledge to go off of. If you were buying from a metal supplier, it could also be 6063 or 6101, but I doubt that the big box stores will stock more specialized alloys like that.Last edited by Hillbilly Welder; 06-04-2016 at 09:44 PM.
Reply:I picked some 1/8"x2" and 1/4"x2" from Home Depot a few months back and it welder fine, I used 4043 filler. Made some gas can holders for the race trailer.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2026-1-3 03:14 , Processed in 0.098658 second(s), 18 queries .
