Welding leads
发表于 2021-8-31 22:05:10 | 显示全部楼层 |阅读模式
I acquired longer leads but the plugs don't fit my welder.  Trying to find out what plug I need.  My welder is the new ahp alphatig.
Reply:I have no idea what plugs would fit that welder.  But you could probably just leave your originals hooked to the welder, take the stinger / ground clamp off and replace them with a commonly available connector like Tweco, then put the matching Tweco / whatever ends on your new leads and go to town.  Basically making your original leads be the adapter whip between the machine and your new leads.  This works if your old leads aren't too tiny to deal with the added resistance of a longer circuit.
Reply:PM soutthpaw on here or maybe see this and chime in. But I'm thinking Dinse 50's."You can't out puke a buzzard"
Reply:http://www.amazon.com/Miller-042465-.../dp/B003GM609O get those they adapt to a reg tweco plug I use them on the ahp and the xmtsHigh Octane Welding
Reply:Just ordered those adapters, thank you
Reply:I'm sure that SouthPaw could help you out!Forney C5 Arc WelderLincoln Idealarc 250-250 Ac/Dc Arc WelderMiller Bobcat 225g PlusLincoln PowerMig 200Forney O/A Rig
Reply:https://www.google.com/url?sa=t&sour...AoDIttojkVfl7w here is a set thats cheaper and even cheaper Lenco 05335 Lda (Set) http://www.amazon.com/dp/B00AB3LHKS/..._y6Kuxb1AV4AN1Sent from my LG-H811 using TapatalkLast edited by WeldorWes; 06-03-2016 at 11:46 PM.Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Yes, the Lenco will be cheaper. You can just buy the size 50 Dinse male connectors too. If you buy the adapters you still have to buy the Tweco style male ends. Tweco has the Dinse connectors too.
Reply:Originally Posted by Welder DaveYes, the Lenco will be cheaper. You can just buy the size 50 Dinse male connectors too. If you buy the adapters you still have to buy the Tweco style male ends. Tweco has the Dinse connectors too.
Reply:Originally Posted by WeldorWesWe still dont know what ends are on his leads if i would have to take a guess its prolly lc40 since its one of the most common Sent from my LG-H811 using Tapatalk
GMT+8, 2026-1-3 03:40 , Processed in 0.101501 second(s), 18 queries .
