Lincweld 295 AC
发表于 2021-8-31 22:05:08 | 显示全部楼层 |阅读模式
I have recently acquired a Lincoln "Lincweld 295" AC machine, but I can't seem to find any information on when it was produced, or what it might be worth.If anyone can offer some information on this machine it would be greatly appreciated!
Reply:The Lincoln machines will have a code number and serial number. Go to the support section of their site and enter the code number. This will retrieve the proper manual for your machine. As to production date, they have a document on their site that lists the starting serial number for each year's production.Good luck,PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Is that a lincweld 275 or 295 ? Did not find a 295 in the master list. Found a 275 though.Look for a code number on the front name plate and post a picture here.Does it look just like the current model the AC225 available at home centers and welding supply stores.?
Reply:ccawgc, it's a "AC-295-S? anyway that's the manual I found when typing in the code number 2716 stamped on the front of the machine. It's a Tombstone style, or what I would call a buzz box.I would like to know what year it was produced and any particulars about how good or bad the machine was, and what it might be worth. Personally I would rather have a DC machine, I already own a Power Mig 255C, but thought this machine might be alright for outside jobs on windy days.I have included a few pics for your viewing.Thanks Attached Images
Reply:WTF?  When I go to the Lincoln support site and type in 2716 (like you said), I get a manual for some OLD Edison battery charger!There should be a date on the manual you obtained... that should give you the year it was first in production.As Papa said, "As to production date, they have a document on their site that lists the starting serial number for each year's production."Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:the code is 7216. If I read my chart is was made some time in 1972. If there is a dash and three more numbers we can narrow it down to the month.Sense there isn't a parts book anymore for this welder, some parts are going to be hard to get. A good welder tech might be able to match up a close match and make them work.It should be a good AC ac welder.
Reply:Thanks guys, what rod would you recommend for mild steel ?As well what would the machine be worth if I decide to sell her?Thanks
Reply:Originally Posted by DALECO...As well what would the machine be worth if I decide to sell her?
Reply:Ok, If I want to install new leads do they have to be soldered on inside the machine?If so is this tricky?As well, can I add longer leads, or should I stick with the stock length?Can the stinger be upgraded, to something newer? I noticed the instruction manual mentions soldering at the stinger end? Can I just get buy with a socket and set screw?Thanks for answers to my many questions!
Reply:Found it on Lincolns web site on operators manuels scroll down and its there AC-295-S date 1972
Reply:Originally Posted by DALECOOk, If I want to install new leads do they have to be soldered on inside the machine?If so is this tricky?As well, can I add longer leads, or should I stick with the stock length?Can the stinger be upgraded, to something newer? I noticed the instruction manual mentions soldering at the stinger end? Can I just get buy with a socket and set screw?Thanks for answers to my many questions!
Reply:Thanks to all for some great input!Rick, I appreciate all the technical advice and will consider  your comments  before any upgrades.Thanks again to a great bunch!Keep on a keepn on..........
Reply:The weld leads could have lugs and it could be soldered. Lincoln did it both ways and there is know way to tell unless you look inside. Most of the new electrode holders use a set screw to hold it on the lead. If you are going to keep it, put leads. If selling it, Make sure it works good and let the new owner put new weld leads on.
GMT+8, 2026-1-3 03:24 , Processed in 0.101189 second(s), 18 queries .
