Water cooled Tig on V205T???
发表于 2021-8-31 22:05:06 | 显示全部楼层 |阅读模式
how do I add a water cooled TIG to a V205T?  I have 2 coolers I can use but both run water through the power cable.  the V205T runs the gas through the power cable and the gas connection is internal.  Is there some sort of plug adapter that will me to bring the gas  out at the plug so I can connect it to the correct line going to the torch?   Links, suggestions ThanksTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:you will need a --water cooled torch.. they have 3 hoses 1-water/power- will have a lug to go to power lug2-water 3- gashas been some discussion on which way to run water in/ outLast edited by prop-doctor; 10-11-2011 at 03:45 PM.idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Yep prop Doc, I was in on those discussions.  I have a model 20 water cooled torch,  a Bernard cooler and a Miller radiator 1 cooler and I have the power lug adapter.   I don't see a way to get the gas separated without opening the machine up and putting a T with a valve in for the gas line.  the torch is all hooked up to the miller cooler.   I would just run the SMAW stinger to the lug for power.   then I have no gas hookup point off the V205TLast edited by soutthpaw; 10-11-2011 at 04:22 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:looks like you may need to get the adapter kit from lincolnwhat torch are you trying to use ?looking at the pdf file on that machine, they show a water cooled torch for said unitidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Thanks Doc,  I missed that when I looked.  Found it here on page 86http://www.tig185.com/pdfs/counter_tig.pdfHas pic of it too.  now gotta find a cheap place to order it...  part is K1622-4  off to browse the online welding storesTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:happy to be of helpidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
GMT+8, 2026-1-3 03:24 , Processed in 0.089268 second(s), 18 queries .
