Are they really worth it?1990 SA 200Miller 225 Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:What's a Big Line Kit?
Reply:I just googled it and first response was this page....1981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
Reply:???
Reply:Oil lines that feed your oil filter. I understand they have larger lines for the sa200's and just wondered if anyone here knows the particelars about them.Thanks1990 SA 200Miller 225 Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:I presume we're talking about a Continental mill.One thought - The small line may be an engineered restriction that keeps the filter circuit from bleeding-off too much volume.And of course the feed is still via 1/8" NPT fittings.What are the claimed benefits?Good Luck
Reply:Seeing as the F-162/163 oil filters are a by-pass type and not full-flow, the volume of oil flow to the filter is orifice controlled.What exactly is the selling point of a 'Big Line Kit'? More oil flow to the filter?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Well I guess denrep and I were thinking along the same 'lines'. I just got a little delayed in hitting the Post Quick Reply button.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:More flow is all I can think of if the hole in the block will let it flow more. My thought is what size is the hole that feeds it? I dont know, I see pics on Weldmart and Bills welder repair. But I would rather ask people that run them than the people that sell them.lol1990 SA 200Miller 225 Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:probably would benefit more from capacity increase than flow increase. Some have the stainless hose lines and a bigger filter, some use hydraulic lines. I think the gain is mostly cosmetic."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:The upper hole in the block is 1/4-inch NPT, the bottom hole in the block is 1/8-inch NPT. Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:So bigger lines wont help. I supose a bigger filter might hold more and would be more helpful than bigger lines.1990 SA 200Miller 225 Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:As stated in post #7, by-pass filter flow is orifice controlled to prevent a severe loss in oil pressure regardless of line size. Whether an older style cartridge or later spin-on type filter, both control total flow rate by way of an orifice as shown below.Spin-on control orifice (red arrow) is on the 'return to sump' outlet of the filter. Black arrows point to filter inlet openingsCartridge filter orifice is located in the inlet riser tube (yellow arrow). Notice it's the same size as the spin-on filter control orifice.Riser tube is unrestricted and the cover bolt seals off flow to force oil thru the control orifice.A larger filter would extend filter change intervals but even without the orifice photos I would have called 'myth' on any Big Line Kit claims to better filtration. Last edited by duaneb55; 06-26-2010 at 04:41 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks a lot that is good info. Nice pics1990 SA 200Miller 225 Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Duane, good info on the filtration system! My onan gererator plant uses the same Continental engine, F162 and uses a Wix c3p filter. Maybe useful to some. Thanks Bob. |
