Sweeeeet plasma cutter
发表于 2021-8-31 22:04:57 | 显示全部楼层 |阅读模式
Dude...This thing is sweet.http://www.ebay.com/itm/Avortec-2015...item339f12ce93
Reply:Lol Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:If Miller or Lincoln advertised like that I don't think they'd sell many machines. Smoke and mirrors...
Reply:SPOOL GUN CAPABLE NEW 2015 , NOW AVAILABLE CALL AVORTEC FOR DETAILS, COME WITH THIS MODEL AV5XL+MIG  17 FOOT CABLE SPOOL GUN MIGNEW FOR 2015.  YOU CAN NOW USE THE MIG TO FILL YOUR FILLER MATERIAL FOR TIG WELDING FOR FACTORY TIG/ MIG WELDING BEADS YOU CAN GO SLOW OR YOU CAN FLY WITH THIS METHOD , NEVER WAIST FILLER MATERIAL AGAIN USE JUST WHAT YOU NEED AS YOU FEED FROM THE MIG SPOOL GUN AS YOU TIG WELD!!!! THIS IS FUN AND EASY AND IS FAST AS YOU WANT TO WELD NOW !!THE MIG SPOOL GUN WELDS , GAS WELDS, OR CAN USE  FLUX CORE (NON GAS WIRE ) , MATERIALS IT WELDS ARE ALUMINUM, STAINLESS STEEL, STEEL, ALLOYS OF ALL KINDS. PRETTY MUCH WHAT YOU CAN FIND FOR WIRE YOU CAN USE IN THIS MIG SPOOL GUN TO WELD YOUR METAL MATERIAL WITH. WE HAVE CERAMIC BARRELS AND TIPS NOW WITH THIS MACHINE FOR THE MIG , TALK ABOUT MAKING THEM LAST, WE DID IT.AVORTEC AV5xL+MIG NEW-Pluse-SQUARE WAVE- NO FOOT PEDAL NEEDED TO OPERATE THE TIG, BUT IS INCLUDED FOR FREE-AC-AC/DC-DC TIG Welder, PLASMA CUTTER, ARC Welder COMBO PRECISION ALUMINUM TIG, - upgradeable to water cooled tig torch (optional) AND OPTIONAL WATER COOLED THUMB REMOTE AMPERAGE CONTROL TIG TORCH OR AIR COOLED THUMB REMOTE TIG TORCH.THIS WELDER IS HIGH OUT PUT AMPERAGE, WHEN TIG WELDING AT HIGHER AMPERAGE'S IS BEST TO USE A WATER COOLED SYSTEM THAT WE HAVE OPTIONAL YOU WOULD RECEIVE A WATER COOLER AND WATER COOLED TIG TORCH ALONG WITH A AIR COOLED TIG TORCH. PLEASE ASK US IF ANY QUESTIONS, WE CAN HELP YOU GET THE SYSTEM THAT FITS YOUR COMPANIES NEEDS. THIS MACHINE USES IGBT'S FOR YEARS AND YEARS OF CONSISTENT DAILY USE, FACTORY PROVEN TO BE THE BEST . {MOSFETS WILL NOT HANDLE AMPERAGE'S OF A AC/DC TIG WELDING MACHINE }, THIS is WHY WE USE IGBT'S SMOOTH, CLEAN, PRECISE FREQUENCIES, MEANS THE BEST STRONGEST WELDING WELDING POSSIBLE. ++++++Our Av5xL+ MIG is 100% duty cycle at  250 amps-is built right and built to last !        why would you buy a 30% TO 60% duty cycle welder ?, THEY ARE  built cheaper and will not last ! compare .call us at  989-640-3131 Avortec.com !! ANY QUESTIONSFREE WELDING HELMET WITH THIS AV5XL+MIG, FREE SOLAR AUTOMATIC ADJUSTABLE 9-13 DIMNESS CONTROL FOR ALL MODES OF OPERATION TIG-ARC TO PLASMA CUTTINGINDUSTRIAL STRENGTH | PROFESSIONAL GRADE | DIGITAL SERIES --- THIS TIG/MMA WELDER IS WHERE YOU NEED NOT PAST EXPERIANCE TO OPERATE LIKE A PRO IN A SHORT AMOUNT OF TIME , MANY CAN START OUT TIG WELDING ALUMINUM WITHIN MINUTES OF SETTING THIS MACHINE UP, WE HAVE TAKEN THE GUESS WORK AND SCHOOLING NEEDED OUT OF TIG WELDING . THIS AV5X IS HIGHLY ADVANCED HIGH TECH MACHINE.  TIG Welder - 250 AMP   AC-AC/DC-DC TIG Welder-FOOT PEDAL CONTROL INCLUDEDPILOT ARC PLASMA CUTTER- 60AMP THE POWER TO CUT METALS UP TO 1" OR BETTER !! INCLUDING RUSTY METAL PERFECT FOR AUTO BODY REPAIRS AND CUSTOM FABRICATION OF ALL KINDS.ARC/MMA Welder - 250 AMP ARC WelderFeatures -Pluse-square wave-crater control,ect,ect. THIS OPTION ALLOWS YOU TO TIG WELD WITH OR WITH OUT A FOOT PEDAL FREE YOUR SELF UP FOR THOSE UNDER OR OVER THE CAR CUSTOM TIG WELDING JOBS.Advanced Power Technology Built In - Hi-tech Circuity100% DUTY CYCLE ON TIG ALUM, STEEL AT  FULL 250AMPS allows you to weld continuously. TO RUN 100% DUTY CYCLE WE WOULD ADVISE A WATER COOLED TIG TORCH KIT -SOLD SEPARATELY. OR AS COMPLETE SYSTEM PACKAGES.TIG /ARC Welds ALL Metals Quickly And EasilyPLASMA CUTTER CUT THE METAL NOW!!Digital Controls And LED Digital Display!Digital Amperage GaugeTIG Welder - Uses A Tungsten ROD (included), ArGON gas, and electricity to weld metal TITANIUM, STAINLESS STEEL, ALUMINUM, CAST, BRASS, COPPER, gold,silver, STEEL, INCONEL- HARDEST MAN MADE METAL , CUSTOM METALS CAN BE DIALED IN FOR ACCURATE TIG WELDING ARC/MMA Welder - Use standard welding rods to weld metal including steel, and aluminum.CUT METAL TO 1 1/4" OR MORE !Electronically Activated LF- TIG AND PLASMA PILOT ARC Torch HandleS -TOUCH Simply click-to-light .Easily TIGS metal up to 1/16" and even 3/4".  high frequency click to activate the tig Easily  TIG /ARC WELD most any metal including: steel, stainless steel, aluminum, TITANIUM brass, copper, iron and cast iron. Clean WITH PRECISION.Power Supply - 220V/50A Power Supply. 220V/Single Phase. *Requires 50 Amp circuit breaker. 40 AMP BREAKER WILL DO FINE. IF USING A GENERATOR A 10KW IS RECOMMENDED ON HIGH IDLE 8KW IS MINIMUM Outperforms most standard 110V/220V welders . We have tested other manufacturers 110/220V welders and found they do not perform on standard 110/15Amp circuits. A 220V/40 50Amp circuit breaker is recommended to perform as specified.ArGON/CO2 FLOW Regulator  Ultimate TIG Welder and ARC WELDERThe AVORTEC Advanced Power Technology welder and plasma cutter represents a leap forward in metal fabrication equipment. With digital controls for accurate cuts and welds on a broad range of materials everytime you will increase your productivity and quality on everything you cut and weld.Digital Controls With LED Readout DisplayShows Modes: ARC Welder or TIG WelderDigital AMP ReadoutDigital FULL ROTARY DIGITAL CONTROLS  allow you to select modes, adjust AMPERAGE and CONTROL WITH PRECISION YOUR TIG WELDING FOR ALL METALS. THE MOST COMPLETE WELDER SOLD ON THE MARKET TODAY WITH THE RELIABILITY OF AVORTEC TO STAND BEHIND IT UNLIKE THE COPIERS AND DUPLICATORS,  WE SELL WHAT WE KNOW WORKS FOR THE WORKING PEOPLE OF AMERICA THAT NEED RELIABILITY !!       FREE HELMET SOLAR AUTOMATIC 9-13 DIMNESS CONTROL INCLUDED FOR FREE       FREE SET OF PLASMA CONSUMABLES      FREE TUNGSTEN INCLUDED 7"      FREE STARTER SET FILLER RODS  STEEL AND ALUMINUM      FREE 3 WAY VALVE NEVER UNHOOK YOUR LINES FROM YOUR BOTTLED GAS OR AIR COMPRESSOR AGAIN WE ARE THE ONLY ONES THAT HAVE DONE THIS FOR OUR CUSTOMERS , SIMPLY TURN A VALVE AIR TO ARGON OR VICE VERSA . Advanced Electronically HF- Activated TIG AND PLASMA Torch Handle200 AMP MIG SPOOL GUN INCLUDED IN THIS SYSTEM NEW FOR 2015 !!!! WITH CERAMIC BARRELS AND TIPS ,TALK ABOUT LASTING FOREVER WE HAVE MADE IT NEARLY POSSIBLE NOW FOR YOUR TIPS TO LAST FOREVER . THIS IS BRAN NEW TECH.17 FT. PLASMA Torch CABLE17 Ft. GROUND CLAMP Cable17 FT. ARC/MMA Welder Electrode Holder Handle Power Cable 220V - 8 Ft. with 220V/50A PlugARGON/CO2 flow REGULATOR free included !AIR/WATER SEPARATOR REGULATOR FREE STAINLESS STEEL 3 WAY VALVE . KEEP YOUR GAS AND AIR LINES ALL HOOKED UP AT THE SAME TIME ,ONLY AVORTEC HAS THE PATENT ON THIS. User Manual WHEN COMPARED TO THE OTHER NAME BRANDS YOU WOULD HAVE TO BUY A $6,300.00 TO $16,000.00 TO DO WHAT ARE STATE OF THE ART TIG/ARC WELDERS DOES WITH EASE .AND WITH THIS YOU CUT, TIG, MIG SPOOL GUN WELD AND FILL, AND ARC WELD !!!!NEW and in the box.Warranty5 Year AVORTEC Manufacturer Warranty.We engineer these to be the best and stand behind our products.Demo AvailableWe can show you how to use the product and demonstrate its capabilities when you pick up locally.ShippingShipped UPS Ground For Easy Tracking.We ship with UPS for low cost and reliable easy tracking.Email us at our ebay account for more information or global shipping options.About AVORTEC Inc.Avortec advanced power technology products utilize top quality materials, and high tech materials. We design, engineer and test all our products. All of our brand name products are NEW, competitively priced, and conveniently shipped direct to your home or business.We test all products to be the best in durability, warranty, style, utility and value.Copyright2002-2014 AVORTEC and AVORTEC.com is a registered trademark of AVORTEC Corporation. All rights reserved. All other trademarksare the property of their respective owners.TIG WELDER, ARC WELDER PLASMA CUTTERLast edited by AKweldshop; 04-01-2015 at 02:00 AM.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Good lord...it looks like a case modded pc gaming rig...I honestly have to admit though, there's a sick part of me that would like to run it at max output for a couple hours of solid non stop weld and see if it survives.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:I'm still laughing....."We've taking the schooling out of tig welding"..... Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Meh. If it had a hotplate built in so I could cook a grilled cheese while I worked then I might be interested.
Reply:umm..
Reply:Ya, amazing.
Reply:The pic is so awesome I'll have to sell my Airco and run right out to buy one Check out the welding related question/answer.....Just needs a Mr. Tig approved sticker to be perfect..... Last edited by MinnesotaDave; 04-01-2015 at 06:28 AM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yikes
Reply:I have GOT to get me some LED strip lights for my machines!  I had no idea I was behind the times on the latest pimped out welding equipment!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by GravelI have GOT to get me some LED strip lights for my machines!  I had no idea I was behind the times on the latest pimped out welding equipment!
Reply:Are those led lights hooked up to flash when something fails on the machine. Kind of like the horn and flashing light when a nuclear reactor melts down.
Reply:It's the Pimp My Ride model.. Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:I want one with a disco ball.
Reply:Originally Posted by 7A749It's the Pimp My Ride model..
Reply:Originally Posted by shovelonWait!Country of origin USA. Michigan in fact.Steve, you have been busy!
Reply:Originally Posted by MinnesotaDaveIt's a side business for him - nothing to clean on a new machine, so he had to pimp it out with some bling and some lighting effects
Reply:April Fools...LOLOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Is that thing already on fire?Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by Doug247Is that thing already on fire?
Reply:Where is Abortec made?
Reply:Originally Posted by shovelonWait!Country of origin USA. Michigan in fact.Steve, you have been busy!How many watt amp and speakers? USB input? Sirus radio ready? WiFi? Bluetooth? Captioning and parental controls? Fersure needs sleep timer for when you pass out.
Reply:I like my gear a little more simple and straight forward to set and operate, like in this pic.
GMT+8, 2026-1-3 03:24 , Processed in 0.118201 second(s), 18 queries .
