The miller has the 18 hp onan. The hobart has only 500 hours. The millers hours are unknown. Both are the same price.HH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:The Miller is going to be older (still a good machine) and have AC/DC weld output whereas the Champion is DC only which is mainly a problem only if you intend to do any typical aluminum TIG welding (that would also require an HF arc starter such as a Miller HF251-D with either machine).MIG or Fluxcore welding would require a Voltage Sensing (VS) type wire feeder with either machine as well.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:The Miller will generate power at 1800 RPM, and weld at 3000. Quieter machine, but less generator power. (about half as much)Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Do you think they are both work 1000 individually. Both run and weld fine.HH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Prices vary from region to region and I'm not familiar with the market in yours but that's more than I'd be willing to pay for either unit.But then, I don't need another welder. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:http://up.craigslist.org/for/4927469151.htmlThat's the Hobart. What would you pickHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Miller without a second thought. That Hobart looks pretty beat for 500 hours Sent from my iPhone using Tapatalk
Reply:I think so too.HH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:More like a 500hr torture test I'd say.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55But then, I don't need another welder.
Reply:The Hobart is actually a Miller Bobcat. The case is beat up and it's missing some panels but I've seen a lot of machines in the back of trucks all beat up that still work fine. If the machine was maintained and works properly is more important than what it looks like.
Reply:Originally Posted by Welder DaveThe Hobart is actually a Miller Bobcat. The case is beat up and it's missing some panels but I've seen a lot of machines in the back of trucks all beat up that still work fine. If the machine was maintained and works properly is more important than what it looks like.
Reply:The Hobart is much newer than the AEAD and its a much more refined machine.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720 |
