Tig adapter for arc welder
发表于 2021-8-31 22:04:54 | 显示全部楼层 |阅读模式
I am hooking up a tig welder to my arc welder - a lincoln invertec 350vs pro.I bought a tig torch kit from weld supply on the recommendation of people on here.It came with an adapter like this http://www.cometsupply.com/mp/WELDCR...FQuMaQodggwAhQ that you would normally clamp your electrode holder on to.My problem is I use Bernard short stub electrode holders so I can't clamp to it. I was thinking maybe just get a short piece of welding lead and put a dinse connector on one end to plug into the welder and on the other end put a lug and use some washers and bolt it to the tig adapter. This would work but I am wondering if there is something that would be better.
Reply:Get a one piece Dinse adapter torch set up and be done with it. You can ask them to put a longer gas line on it and get a torch with a valve and you're good to go. Here's a basic kit. They sell them about any way you want. You can order online, or give them a call and they can set you up and answer any questions you have. I deal with Paul there. Always been knowledgable and very helpful. Sometimes getting someone on the phone is the easiest way to get it sorted.http://www.usaweld.com/Lincoln-TIG-T...05tigtorch.htmWhatever the case, skip the BS and get a CK torch with SuperFlex line on it. Best there is as far as line goes and their torches are top gear all the way.IMHO of courseExpert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:^^^ they make the connector and kits with much longer gas hoses. I can't stand those adapter y pieces, I can see how they could be handy on a remote weld when you've got a **** ton of lead all ready . like on a iron job.esab 260 multimasternew tech 150 invertorlincoln 140 cheapo
Reply:im in the exact same boat right now, need to find out whats out there for this... the hole in that unit is too big to just run a bolt thru and add an eyelet on the end of the welding cable... must be something better!
Reply:Originally Posted by jr tig^^^ they make the connector and kits with much longer gas hoses. I can't stand those adapter y pieces, I can see how they could be handy on a remote weld when you've got a **** ton of lead all ready . like on a iron job.
Reply:Originally Posted by rambinim in the exact same boat right now, need to find out whats out there for this... the hole in that unit is too big to just run a bolt thru and add an eyelet on the end of the welding cable... must be something better!
Reply:Originally Posted by Drilldo... I was thinking maybe just get a short piece of welding lead and put a dinse connector on one end to plug into the welder and on the other end put a lug and use some washers and bolt it to the tig adapter. This would work but I am wondering if there is something that would be better.
Reply:Originally Posted by DrilldoI am hooking up a tig welder to my arc welder - a lincoln invertec 350vs pro.I bought a tig torch kit from weld supply on the recommendation of people on here.It came with an adapter like this http://www.cometsupply.com/mp/WELDCR...FQuMaQodggwAhQ that you would normally clamp your electrode holder on to.My problem is I use Bernard short stub electrode holders so I can't clamp to it. I was thinking maybe just get a short piece of welding lead and put a dinse connector on one end to plug into the welder and on the other end put a lug and use some washers and bolt it to the tig adapter. This would work but I am wondering if there is something that would be better.
Reply:nice...just rmbr to reverse your polarity!!
GMT+8, 2026-1-3 03:40 , Processed in 0.101237 second(s), 18 queries .
