First stainless project- motorcycle battery box
发表于 2021-8-31 22:04:50 | 显示全部楼层 |阅读模式
16 gauge 304 stainless and 1/8" bracket. Did all fusen welds. Was pretty fun accept blowing out that one dang edge lol. This is not the stock location or battery size, its much lower and lighter. I think I saved 15 pounds.  I'll put some padding on the inside of the cage. Or silicon like the last one I made. There was no sugaring either. I used 5 cup at 10cfh 1/16 red. Switched to 7 cup at 17 cfh and seen no difference in color so I went back to the normal setup.  Attached Images
Reply:Nice!Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by AKweldshopNice!
Reply:plenty of room to get to the fuel bowl screws and a bunch of room to get to the jets, you can get to the need too very easy. I won't even have to take it offthis is about the most fancy carb you can get for a bike. Has a really long needle and has roller bearing on the flat slide, hopefully they don't get too annoying because they are a really loose fit. This carb was hacked so bad too lol. I gave it bunch of tlc
Reply:You could back that blown out corner with a copper piece and fill it in then file down the blob so it looks good.If you tack all the corners first then when you approach an end while welding, the 2 pieces will be more prone to flowing together rather than apart. You have to really watch it and kill the arc as soon as it flows together. Also the part heating up will usually cause the end side to blow out easier.Last edited by MikeGyver; 05-07-2015 at 05:23 AM.Welding/Fab Pics: www.UtahWeld.com
Reply:Can't if crack if I let off real fast or not so much with stainless?ive only welded it a few times because of the price but man it welds nice like butter lol
Reply:do you mean here mike? I was speed tacking it in the middle. Would you speed tack a corner like that?
Reply:Looks good bud. What (if anything) used to be where the battery is? That's a pretty big space to have just been empty. Will accessing the battery be any more difficult now? And are you adding some sort of strap to keep the battery in place?
Reply:Thanks man!there will be a big k&n filter behined the carb taking up most of the room. I was gona put a air tank in there and horn but got sketched out becuase it was PVC pipe the black kind, that was before I learn how to weld AL. Battery before was really high way bigger and there was no space like there is now. There room for hands now for jetting
Reply:did some surgery
Reply:Yes I would definitely speed tack the corners, especially the ending corner as this will help the metal flow together instead of apart when you weld it there. I wouldn't ever tack in the middle of a short weld like that because you'll likely see a wider haz in the middle and a tack on each end seems more appropriate to hold the thing from moving around as it's being welded.And when you speed tack, lay the wire between the 2 pieces and you can tack even if  there is a gap, pulse right on the tip of the wire. This will also leave a humped up tack which can help with filling in the crater at the end of a weld.Last edited by MikeGyver; 05-07-2015 at 04:59 PM.Welding/Fab Pics: www.UtahWeld.com
Reply:You mean butt the filler rod against the stainless and speed tack it so it pulls in some filler?
Reply:Originally Posted by motolife313. speed tack it so it pulls in some filler?
Reply:When you set the amps to about double you would normally use for the metal your welding and you floor the pedal for a split second. It works really good for 1/8" or lower or for thicker stuff you gota hold the pedal down longer. I set the machine to 120 amps for this. It fuses the metal so quick you can put your finger on the tack right after. I do it with AL now too alot. It's not as forgiving as steel tho no filler used with this technique. I've done it a few times with no hood on and you get a tig sun burn really easy even if you only do a few tacks
Reply:Originally Posted by motolife313You mean butt the filler rod against the stainless and speed tack it so it pulls in some filler?
Reply:You welded this without any filler? Why?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by MikeGyverYou know how when you do this with a gap both pieces just melt away from each other? the filler bridges the gap so the arc can kinda blast the whole area, and adds just enough filler to bridge the gap.
Reply:no gap, it will sugar the back sideWelding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyverAnd when you speed tack, lay the wire between the 2 pieces and you can tack even if  there is a gap, pulse right on the tip of the wire. This will also leave a humped up tack which can help with filling in the crater at the end of a weld.
GMT+8, 2026-1-3 03:32 , Processed in 0.094187 second(s), 18 queries .
