Adjustable band saw material support.
发表于 2021-8-31 22:04:49 | 显示全部楼层 |阅读模式
I have a harbor freight horizontal band saw. In order to fit it under my welding table for storage I built a cart for it that sits maybe 8" off the ground.Problem I run into is long stock is hard to support because I find myself grabbing random objects to get the proper height.Came up with this little thing as a possible fix. Going to try and tig weld the entire thing for practice that I desperately need. It stands 5.5" at minimal height and extends up to 8.5" the way it is designed now. I don't have the exact heights I need sitting here at work, odds are it needs to be a couple inches taller though.Attachment 1101601Attachment 1101611Last edited by BrooklynBravest; 05-07-2015 at 01:53 PM.www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:I used some nested square tube to make a support. It is attached under the saw. Because of the slop, I just adjust the support up or down depending on how far out I pull it. It actually works pretty good. Then pushes back into a compact size when not in use.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Burt, what sizes of tubing did you use?  That looks like great!
Reply:Originally Posted by CraboBurt, what sizes of tubing did you use?  That looks like great!
Reply:Hey, Crabo - I'm not home, but I think it was just 1", 1.25", and 1.50" square tube. Probably 14 gauge. The trick is the square nut in the ends for the threaded rod to go up and down easily.Brooklyn - it was just some scrap I had. You are correct if I had to buy a full stick of each it would have been costly. As far as weight, when I built the stand for the saw, I used a heavy piece of 2" x 8" (If I remember right) x 3/16" rectangle tube under the saw, so there is sufficient weight to be stable for what I do. It would be simple to have an all thread to go to the floor for support. BTW, my daughter lives in Brooklyn, near Park Slope.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:This is a little more difficult and expensive if you have to buy a stik of tubing and wheels, but for me it was really worth it.The top of the stands are even with the bed of the saw.  The bar that flips up is the same height as the table.  We often put heavy objects on the stands and roll them around.
Reply:That's a great idea, Crabo.I made my welding table, my burn table, and another long table all the same height for that reason. I can use them to hold long material. But my saw is much lower - I can adapt this idea and add a support under my burn table the height of the band saw!Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Go buy the HF heavy duty hyd lift table. Handiest tool you'll have. I find more and more uses for mine.                                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:What would make that work better is a roller so the material doesn't need to slide which can drag or tip your stand. I'm not home now or I would post pics of mine. Rollers are great in that use.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:I used the sliding half of a 3/4 pony pipe clamp that I bought for a buck that works well. Here's the post, http://weldingweb.com/vbb/showthread.php...ny+clamp+light
Reply:BD1 - good idea!I'll steal that if you don't mind.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Originally Posted by wb4rtBD1 - good idea!I'll steal that if you don't mind.
GMT+8, 2026-1-3 03:22 , Processed in 0.068024 second(s), 18 queries .
