Rolling workstation for my CNC plasma
发表于 2021-8-31 22:04:47 | 显示全部楼层 |阅读模式
At my old place I just had a makeshift shelf for my computer and has the cnc controls on the ground.  Now that my air is done and most of the garage is setup, I wanted something to keep my computer/plasma and miscellaneous stuff together, along with a place to work and run the plasma.  I thought about buying something, but like everything else, I can never find anything I like that isn't expensive, so might as well just build what I want.  The frame is 27x33", top a little bigger than that.  Top is 1/8" aluminum, bottom shelf is roughly .030 steel, 1.5" dimples with a die I made on my lathe, shelf bent up on a Roper Whitney Magnabend.
Reply:Nice job.
Reply:Very...the stuff in my garage never looks that pretty...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Looks very nice,i like the radius front of the table top.Lincoln Electric Square Wave Tig 275JD2 Bender & Notcher Old 3 phase compressor
Reply:Nice job Kazlx. I made a cart too out of scrap. I also used a monitor mount I modified. Got it from Monoprice.com for like 12 bucks. Sorry for the sideways pic.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Thanks guys.  I will probably do a monitor arm like that when I get it setup just to get it off the desk and bolted down so it won't fall over when rolling it around.
GMT+8, 2026-1-3 03:22 , Processed in 0.100552 second(s), 18 queries .
