Tractor drawbar bracket.
发表于 2021-8-31 22:04:47 | 显示全部楼层 |阅读模式
This is the tractor drawbar bracket that i made to bolt underneath my ford 8n in the factory drawbar bracket. I made a drawbar that pins into it(not pictured) that held up to a 2700# pull last fall. I Don't know why i never posted pictures of it before but forhire's post with the drawbar adapter reminded me to run out and get a few shots of it.Yes... The bolt that held the drawbar up to the bracket is broken, but it was only temporary until i get some time to figure a stronger solution out.The other thing pictured fits in the drawbar to adapt it to an allis chalmers one bottom plow so that i can use it before i get the allis tractor started...... Hopefully.... The engine on it is locked up so i have diesel and acetone in the cylinders to try and loosen the, cylinders up. I put a grease fitting on it because i figured it would last longer, and work better that way. Also, i had never fabricated something with a grease fitting so why not?"I thank God for all the freedoms we've got in this country, I cherish even the right to burn the flag, but I'll tell you what, we've also got the right to bear arms and if you burn my flag I'll shoot you"-Johnny Cash
Reply:What grade bolt was it ?  Depending on usage and location, many are grade 8.This one looks slick, http://www.ntractorclub.com/cgi/view...istory&th=2521  Checkout the last page. Here's a goggle search, https://www.google.com/search?q=8N+d...DwQsAQ#imgrc=_
Reply:Originally Posted by BD1Checkout the last page.
Reply:Yeah... Thats why i opted for the stock location. I made it because they are expensive, even used or aftermarket. I may make on in the future for the swinging drawbar but have no use for it now.Yes, they are grade 8 bolts... Seemed most appropriate. Also, since it supports a sliding pressure, if you can imagine that, the bolts would be more vulnerable to shearing if they get lossened. I have washers and lockwashers on it but no locktite b/c i know ill need to take it off for repairs/modifications."I thank God for all the freedoms we've got in this country, I cherish even the right to burn the flag, but I'll tell you what, we've also got the right to bear arms and if you burn my flag I'll shoot you"-Johnny Cash
GMT+8, 2026-1-3 04:48 , Processed in 0.115699 second(s), 18 queries .
