can anyone tell me what model this is
发表于 2021-8-31 22:04:35 | 显示全部楼层 |阅读模式
he says it is a lincoln 250   he has it for sale Attached Images
Reply:Hello hamm8232, that looks to be a 250 amp self-contained wire feed welder. With the picture  there isn't much to go on to tell you any more. It does look like a couple of machines that we had in our shop at one time. Our particular machines had a drop in wire spool assembly and a plastic framed wire tension top idler roll, not the best system by a long-shot, however, still a decent machine providing the price is right. They are 220V 1ph. so they're well suited for many home shops. Best regards, Allanaevald
Reply:he wants $1000
Reply:looks like a wire matic 250. See if you can get the code number and the serial number.Then i can confirm the model name and the serial number will tell us how old it is.
GMT+8, 2026-1-3 05:04 , Processed in 0.104930 second(s), 18 queries .
