sa200 radiator question
发表于 2021-8-31 22:04:35 | 显示全部楼层 |阅读模式
Does anyone know if there is any sort of rubber that goes between the radiator and the battery box on a sa200 ? Seems like metal to metal might not be so great.
Reply:Yes there is. I generally cut an old tire, and use pieces of it on each side of the bolts. Sometimes I'll even cut washers out of an old tire.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I figured so but there wasn't any between there when I tore this thing apart. Trying to make it ALOT nicer than it was.
Reply:Sometimes you have to use the rubber as a shim pack, to get the correct height for the radiator fill neck at the radiator shroud.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I ran across one that had 1 1/2 cotton webbing used for a spacer/damper
GMT+8, 2026-1-3 05:04 , Processed in 0.163179 second(s), 18 queries .
