Age of welder
发表于 2021-8-31 22:04:33 | 显示全部楼层 |阅读模式
Is there a place to look up the age of a welder uesing the serial num?
Reply:using  the code numbers off lincoln-miller go to their site an look up some of the guys here can tell ya if you supply the numbersSO tell us what kind of welder you got if a name brand we can help if an off the wall type it might be a little tufferidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Every manufacture uses a different system.Lincoln U1 country & plant, next two are year, next two are month, rest are sequence.Miller you can go to their web site, look up the owners manual  and if the welder is not to oldLA and newer it will give you the date it was last tested at the factory before shipping.Or go to a LWS and get the parts booklet and find the serial number page.Or you can post it here or send it to me in a PM.If you are buying an old lincoln I have to look it up in a table. I think I posted that table some where on this site. you might find  it if you look for it.Last edited by ccawgc; 11-01-2011 at 02:13 AM.
GMT+8, 2026-1-3 05:05 , Processed in 0.073213 second(s), 18 queries .
