can anyone tell me give me a guess on the age of this welder?or any other important info. its a sa250 with perkins. can this machine tig? its for sale in my area for $1500.thanks for the help! Attached Images
Reply:well i called and talked to 2 guys about the welder. im gonna go saturday mornin and try one out. he said it would also come with some leads
Reply:It will Tig, (very well), just not AC.Dont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:thats good news! all i have to do is switch the positive to ground and ground to my torch right?thanks
Reply:Your gonna need a reg, Argon bottle and a tig torch with a gas valve on the handle or some other way to control the gas, but it is a strong stick welder, and probably has a generator in case your power goes out in a storm or disaster. I'm not sure, but you might be able to get some "suitcase" type accessories to enhance the DC tig and other capabilities like wire feeders similar to what Miller offers too Just a thought.I'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys? Trade?
Reply:ive got a full tig setup. bottle, reg and all. i was just making sure that the machine could tig with anyother things like a suitcase. the generator puts out 3kw.
Reply:i ment without any other things like a suitcase***
Reply:Originally Posted by welder90i ment without any other things like a suitcase***
Reply:OOOO!!!!! i got mine in all stored in a toolbox! i thought you ment like a box like the mig has to have.
Reply:The front panel of the machine should have a code and a serial number. from these numbers we can get you a date of MFGR. and and owners manual. Call the guy back and ask him for the numbers, post them here. Good buy for a running unit if it is up to speed."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:im goin to see it and check it out saturday mornin. i talked to him last night he said it started(with a jumper pack, dead battery) and held a steady arc. if i get ill get those numbers right on here!!
Reply:well bad news already. . . . ive got the wrong gas. i was supposed to get argon. i got home from work and they delivered argon 75%/ co2 25% gas. it was too late to go exchange. . . . . will this work for just a test weld on this machine? and is there a website to check the serial number and code if this machine?
Reply:Originally Posted by welder90....................... and is there a website to check the serial number and code if this machine?
Reply:Here ya go. Lincoln year of manufacture Service Notice #9301.http://content.lincolnelectric.com/p...parts/9301.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:ok guys i just got home. im now the owner of a welder . the guy put a new battery in it for the price and 20ft of leads. from what ive found its a 1980. thanks for all the help and info !!!!!!!!!
Reply:Post up some pictures!
Reply:finally got some pictures. here ya go!! Attached Images
Reply:Even if you paid hid $1500. I'd say you did pretty good on that!
Reply:a few more Attached Images
Reply:im glad to hear that!.
Reply:well i finally got the hood and doors off. been workin on cleanin it out. so far ive replaced both fuel lines because of cracks and leaks. and im tryin to find the upper coolant hose becauses its cracks and leaks too, the local tractor thinks they can get one. im thinking about repaintin the frame and sheet metal back to factory gray, does anyone have a factory number or close match for the paint? how close would the rustoleum hammer tone black? the sa200 painted with that looks awesome! but i dont wanna paint the motor/generator just yet, so i want a kinda close match.how have yall painted them? roller brush or with air gun ive got a sandblaster and shop to do all the work myself. the only major problem i see is the filler neck on the fuel tank has a hole wore in from the hood. ive added some more pics.thanks for lookin! Attached Images
Reply:That machine was made mid 1980 pre 1981. Its a AC machine, those machines have the wedge exciter you find a lot of those machines for sale. The DC version of the SA250 much better machine much harder to find, you won't find a gang of them in the bone yard for parts. Perkins diesel you cant go wrong. I would look for a old sa200 red-face interchange the barrels you'll have a awesome pipe welding rig if that the kind of work you do. Aside from the barrel and ac exciter nice rig.
Reply:well its finally the weekend! got the exhaust paint flat black and am gettin the paint for the rest tomarrow. the fuel tank is drainned and the hole is gonna be brazed shut tomarrow.what would changing the barrel do?the tractor shop couldnt find a hose number. .does anyone know of the radiator hoses numbers?i found a new faceplate from this place. they have sa200 and 250 parts.http://stumpfweldingsupplies.com/SA250Nameplates.htmlthanks!!
Reply:e bay type in sa200 just like you see it here
Reply:Well if you ever welded with a old shorthood welder from lincoln, you will definately know the difference. Octagon barrel to a round barrel. You can find them online on ebay and parts if you need them.I got the filters today. thought id post up the numbersThese are the numbers oriellys said matched up to a perkins D3.152WIX-OIL FILTER-51460WIX-FUEL FILTER-33166WIX-AIR FILTER-42276and ive got shell rotella triple protection sae15w-40 oil.
Reply:For hoses check the Lincoln parts lists or with Bill's or Hybriweld sites or call them or Stumpfs.http://www.lincolnelectric.com/produ...e/partsnav.asphttp://www.billswelderrepair.com/Engine-Drives.htmlhttp://www.hybriweld.com/http://www.stumpfweldingsupplies.com/For more face plates & decals:http://www.decalshoppe.com/home_pagehttp://www.traysdesign.com/faceplates.htmNever heard of a AC welder SA250 your face plate if it's original says DC welder in plain English does it not ? The auxillary 110V power is clearly also marked AC vs. being only DC auxillary on the plug on a SA200.
Reply:i got the hose from oreillys this mornin. and yes it says dc right on the faceplate?ive got 1 door and the frame left to get sanded down. hopefully by this time next week itll be gray
Reply:Awesome Welder90. I cant wait to see it gray. I love messing with these old things. I wish I could come across a diesel machine for 1500. I have 4 gas sa-200's. I would sell one to buy the diesel but the market sucks! Keep the updates and pictures coming. Looks like a great project.
Reply:You got a good deal on that machine, looks great! Most SA250's I find here in TX are in the $2500-$4000 area. I've been looking for a Shorthood but if I find a deal on an older diesel 250 I'll go that route. As far as the generator goes, the old round barrel all copper wound machines are said to have a better arc than the newer ones do. I've never ran a Lincoln machine that was newer than 1960 so I dont know 'bout that.RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
Reply:thought id add a few more pics. new upper hose on and exhaust painted. im getting a new faceplate and stickers from stumpfwelding. i cant find all the safety stickers so im going to see a local printing shop can remake some. i thought i read somewhere that this was copper wound. Attached Images
Reply:oil and filters Attached Images
Reply:Looking good, Glad to see the RED paint going to gray.
Reply:today i went shoppin for some welding cable. and am in pain! i didnt realize the stuff was so high! 5.29/ft for 2/0. i been lookin online and found 100ft of techniweld brand 2/0 for $285 on harris online store with free shipping. is this anything like the excellene? or is it junk?http://www.harrisweldingsupplies.com...madeinusa.aspxi ran the machine for about 45 mins with no hood, doors or radiator cover on it. it ran 200-205* and around 65-70oil psi. this thing sure out welds my ac225Last edited by welder90; 07-18-2010 at 12:47 AM.
Reply:That sounds like a good price, that cable is US made too so it must be good stuff. If you bought it from the guy on ebay that sells welding cable it would probably run about $310 shipped.RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
Reply:well im gettin ready to order some stuff from stumpf...hour metergas sealdecal kitfaceplateim thinking about gettin the remote control kit too. how hard is it to install? from the picture it looks like 3 or 4 wires. anyone put one on their sa250 machine? its listed under the sa 200 parts page. ...thanks
Reply:ran into my first problem tonight. i ran it for just over an hour oil pressure started out at 65psi and when i heard it start make some racket i looked at and seen 18 psi!! its not leaking any and is just under the max line on the dipstick. not realy sure why it drops but i gotta figure it out fast!!! usin the old ac225 to finish up kinda sucked!!
Reply:Could be normal oil pressure for a older worn engine or other problems yet or just defective gauge or plugged line or bad sender if electric gauge & light been added. Maybe just needs cleaning and flushed out but you saying it made noise it could be a spun rod or main bearing too. Check using another gauge or go ahead and pull the pan making sure oil pump screen isn't plugged then start looking for a spun bearing.
Reply:i hope it aint that bad!!! it sounds like more of a knock. if you let it cool off it goes away but when the oil pressure drops it starts again. im gettin a hour meter and the oil and filters is gettin changed. im ordering all my stuff from stumpf so im ordered all at once. is the gas seal on sa200 and sa250 the same size?
Reply:i finally got some more parts ordered. the faceplate, gas tank seal, hour meter, and 12" lincoln arc decals are coming from stumpf. and the receptacle decal( s-16386) is coming from the local welding store, i ordered 2..... for those that have a sa 250 which stickers does urs have? any pictures or parts numbers would be great.. mine only had 3 stickers total, the rest was covered in paint. i took the face plate off and found some nice paint!!!! the right color too..thanks for lookin! Attached Images
Reply:i got my stuff from stumpf yesterday. pretty fast i thought. i ordered it late thursday night and it was here at 12:30 monday..a few pictures. new faceplate, 12" decals, hour meter, and gas seal. Attached ImagesLincoln Sa-200 F162 Redface bluetint--1961Lincoln SA-250 Diesel--1980Lincoln Power-Mig 180 Dual--2012Lincoln LN-25 Lincoln Idealarc 250 AC/DC--1984
Reply:Looks good! Hows the engine been running as far as the oil pressure?RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
Reply:ive only ran it once since for about 10 minutes. so i dont know.... gotta change the filter and oil still.Lincoln Sa-200 F162 Redface bluetint--1961Lincoln SA-250 Diesel--1980Lincoln Power-Mig 180 Dual--2012Lincoln LN-25 Lincoln Idealarc 250 AC/DC--1984
Reply:i finally got the oil and filter changed. i ran it til the old was warm then changed it. after i ran it for about 45 minutes and it had dropped to 25psi. guess it couldnt have been an easy fix Lincoln Sa-200 F162 Redface bluetint--1961Lincoln SA-250 Diesel--1980Lincoln Power-Mig 180 Dual--2012Lincoln LN-25 Lincoln Idealarc 250 AC/DC--1984
Reply:That is a DC only welder. It will also supply auxiliarly 110/120v AC power to run power tools.Do not use 75/25 gas for DC scratch start tig welding. You will melt your cup o the tig torch. You can only use 100% argon for tig welding.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:i know your supposed to 100% argon. i used the 75/25 for maybe 5 minutes just to test it. they delivered the wrong gas and i didnt have time to exchange it so i made it workLincoln Sa-200 F162 Redface bluetint--1961Lincoln SA-250 Diesel--1980Lincoln Power-Mig 180 Dual--2012Lincoln LN-25 Lincoln Idealarc 250 AC/DC--1984
Reply:can anyone tell me what the sender on the end of the "t" is? it has one wire to the amp gauge and the other to coolant gauge. the oil gauge is mechanical. the oil lines hooks into the t but i cant fingure out what this sender does?!? thanks for any help! Attached ImagesLincoln Sa-200 F162 Redface bluetint--1961Lincoln SA-250 Diesel--1980Lincoln Power-Mig 180 Dual--2012Lincoln LN-25 Lincoln Idealarc 250 AC/DC--1984
Reply:If you wwant to use blended gas for tig welding, you best check this out.http://weldingweb.com/vbb/showthread.php?t=43982JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:i dont want to and i dont now. i just needed something to test it with cuz i was out. i have argon now but didnt that day.Lincoln Sa-200 F162 Redface bluetint--1961Lincoln SA-250 Diesel--1980Lincoln Power-Mig 180 Dual--2012Lincoln LN-25 Lincoln Idealarc 250 AC/DC--1984
Reply:Originally Posted by welder90can anyone tell me what the sender on the end of the "t" is? it has one wire to the amp gauge and the other to coolant gauge. the oil gauge is mechanical. the oil lines hooks into the t but i cant figure out what this sender does?!? thanks for any help! |
