Trailer bearings which grease?
发表于 2021-8-31 15:01:50 | 显示全部楼层 |阅读模式
I haven't re-packed wheel bearings in a long time-except on the boat trailer. My son is bringing his 2 axle flatbed trailer over tomorrow and we are going to do the bearings. Which grease are you guys using on a utility trailer for highway use? We will be hauling off road vehicles on it. I don't know yet if it has disc or drums or if that even makes a difference on a trailer like it did on some of the cars back in the day. There are so many different greases out there and it gets confusing. When I first learned to drive I just bought "wheel bearing grease" end of story.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:any wheel bearing grease.  if it has brakes, use hight temp.lincoln 125spmonkey wards 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dof course duramax diesel
Reply:Tapper bearing in trailers uses what call long fiber grease.If is in water a lot they make a grease for that purpose but cost more. Dave  Originally Posted by bigbI haven't re-packed wheel bearings in a long time-except on the boat trailer. My son is bringing his 2 axle flatbed trailer over tomorrow and we are going to do the bearings. Which grease are you guys using on a utility trailer for highway use? We will be hauling off road vehicles on it. I don't know yet if it has disc or drums or if that even makes a difference on a trailer like it did on some of the cars back in the day. There are so many different greases out there and it gets confusing. When I first learned to drive I just bought "wheel bearing grease" end of story.
Reply:It does not have to be synthetic but most today is synthetic. The long fiber is important it also works truck and car wheel bearing. I buy by can is cheap than tube just use rubber gloves or I big can of soap both works.Dave  Originally Posted by bigbI haven't re-packed wheel bearings in a long time-except on the boat trailer. My son is bringing his 2 axle flatbed trailer over tomorrow and we are going to do the bearings. Which grease are you guys using on a utility trailer for highway use? We will be hauling off road vehicles on it. I don't know yet if it has disc or drums or if that even makes a difference on a trailer like it did on some of the cars back in the day. There are so many different greases out there and it gets confusing. When I first learned to drive I just bought "wheel bearing grease" end of story.
Reply:Packed the bearings on the little deckover trailer back in 2014 when I built it.  Hasn't been touched since.  Valvoline synthetic.  Syn Power Full Synthetic.  Personally, although it's great grease, I think that about 50% of the success is due to setting the bearings right in the first place.I use the same grease on the coupler, and hitch ball.  Excellent wear prevention.  I've got a lot of miles on this, and wear is minimal.Make sure not to mix synthetic with regular grease, it will not work properly.  The synthetic will break down.  Every bit of old grease has to be removed from the bearings before repacking with synthetic.Temp range on this stuff is -40 to 400.  You really can't beat that.  And it's not stupid stiff like so called hi temp grease.  Hi temp grease doesn't work for crap till it gets hot.  This stuff is fully functional at all temps.Anyways..........I like the stuff
Reply:Lucas Oil Red N' Tacky grease, never had a problem.
Reply:Originally Posted by _Weldman_Lucas Oil Red N' Tacky grease, never had a problem.
Reply:I scored some #2 SLICK 59 GREASE, I used it until wheel bearings were sealed & no longer serviceable, I still have about half of a 35 lb pail here somewhere. Awesome grease, it was originally developed for the arm on the space station, full synthetic.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:Originally Posted by M J DSame here. I use the lisle bearing packer, really forces it in and very little waste.
Reply:Tacky grease will earn you a night sleeping on the back porch
Reply:With the dog
Reply:IMHO
Reply:Originally Posted by farmersammmThere is no better bearing packer on the Planet, or in the entire Universe, than the palm of your hand.  Load up, scrape, load up, scrape.And....................you gots silky smooth hands for touching those silky smooth parts
Reply:I like the general-purpose grease by STP it has a nice consistency more like the stuff I used to use and never had a problem with. It says it is only good between 0 to 275 degrees but it seems to hang in there. I am sure I would love the twenty-dollar Mobile one grease too but I hate to experiment. And it would probably take a few days to get.  Some of those red tacky greases after they get warm they move away from the bearings and just sit there. The STP grease is different it likes to get to the hot spot and stay there. I just did a wheel bearing on a Hyster forklift after a leaking brake cylinder had to be replaced, and I used the STP grease. I like its consistency. The outer bearing is bathed in the differential gear oil as well and this seemed like a good match-up to what was still there. There was no raised loading dock that I could use to work on the brake at chest height. So I did the job on the floor, Wow is all I can say. It is so hard to work like that compared to having it at chest height. Sincerely, William McCormickIf I wasn't so.....crazy, I wouldn't try to act normal, and you would be afraid.
Reply:Well errr... we got er done. A bit more work than bargained for. My son had loaned the trailer to a friend who ran it to the dump and back with the breakaway cable pulled out because it was stretched too tight. He told my son the wheels were smoking apparently not knowing what the breakaway cable does, he thought maybe the bearings needed grease Shoulda took pics, actuators were just two melted blobs, no friction material on left side and the right ones fell off, adjusters fell out, basically nothing left. Fortunately it is a Dexter and the trailer store had everything we needed including complete brake assemblies, backing plate and all $65 each, just unbolt the old ones, bolt on the new ones and connect the wires.Since my son wanted to learn all about wheel bearings since he has several trailers, and I didn't want to let Samm down, I taught him the palm method like I was taught (before he was born). Got the grease from the trailer store as well, what they use, it was red and tacky but not Lucas RednTacky.No more loaning equipment.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:A real "friend" would pay for the repair parts and any labor.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55A real "friend" would pay for the repair parts and any labor.
Reply:Good to hear you got the bearings packed. It sucks about the trailer tho. It just goes to show that even very simple things can be screwed up by others.
Reply:not trying to hijack  but i have been using a mystic branded high temp grease with molly    the usual high temp stuff i have used in the pas has been the typical red stuff    do you think the moly is still acceptable for tapered roller bearings?
Reply:Originally Posted by paid-fornot trying to hijack  but i have been using a mystic branded high temp grease with molly    the usual high temp stuff i have used in the pas has been the typical red stuff    do you think the moly is still acceptable for tapered roller bearings?
GMT+8, 2025-12-18 16:20 , Processed in 0.130965 second(s), 18 queries .
