miller extreme
发表于 2021-8-31 22:04:20 | 显示全部楼层 |阅读模式
has anyone had any luck running one of these EXTREMES i've had 2 and neither worked, using lincoln nr 203 wire, tried cv and cc
Reply:great luck powerd by 05 air pack
Reply:Originally Posted by local 1 ironworkerhas anyone had any luck running one of these EXTREMES i've had 2 and neither worked, using lincoln nr 203 wire, tried cv and cc
Reply:parameters.............045 wire  soft stort on c/v llowwire speed  no nozzle 3/8 wire stick out  110-170 wire speed Bobcat low side c/v electrode- voltage fine adjust 3-10 depending on position and thickness
GMT+8, 2026-1-3 05:18 , Processed in 0.272200 second(s), 18 queries .
