using a spool gun on a portable welder
发表于 2021-8-31 22:04:20 | 显示全部楼层 |阅读模式
I have a spoolmate 3035 with the sga 100 controler, origionaly I got it to weld alum with my millermatic 175my question is can I use this setup on a cc/cv engine driven welder, the machine I want to use it on is a Lincoln Sam 400 which is a CC/CV machine and has 120AC outlet that is hot even when weldingis this workable and what should I watch for, I dont want to burn up my spoolgunMatt the Alaskan red neck
GMT+8, 2026-1-3 05:11 , Processed in 0.115534 second(s), 18 queries .
