Idealarc 250/ Airco welders.
发表于 2021-8-31 22:04:16 | 显示全部楼层 |阅读模式
I have a chance to buy a Airco 1-8ADT-2A it's in good shape 50.00 also a Idealarc 250 not sure if it runs, needs plug, 50.00 as well, are they worth buying, I would like to have one so I can use it just for tigging  aluminum with a tight rig, is either one good?Sent from my SAMSUNG-SM-N920A using Tapatalk
Reply:Not sure about the Airco but make sure the Idealarc is the tig model with high frequency. The standard idealarc 250 is an acdc stick welder and a DC only scratch start tig welder as it is not a high frequency start machine.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:looks like it's AC only, I'm not seeing the switch in the upper right corner Sent from my SAMSUNG-SM-N920A using Tapatalk
Reply:Looks like the polarity switch is missing. Or it’s an AC only welder.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPLooks like the polarity switch is missing. Or it’s an AC only welder.
Reply:Looks AC to me.  The second amperage scale for DC is not there either.Well worth $50 in my opinion though.Doesn't the ad say $150 ?Last edited by MinnesotaDave; 06-11-2016 at 05:59 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:If there's no rectifier and inductor, adding a switch won't help.  There is no lower DC current scale either.  The really old AC ones had the knockout and holes for the switch, and the faceplate around the on-off switch.The Airco 1.8ADT-2-A is a 180 Amp AC stick welder, same as a Miller M-180.http://www.millerwelds.com/resources...ed-information"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by Brax..And is it worth 50$
Reply:Originally Posted by MinnesotaDaveLooks AC to me.  The second amperage scale for DC is not there either.Well worth $50 in my opinion though.Doesn't the ad say $150 ?
Reply:It's AC only and its old 58-61 or so. You can tell by the plate around the line switch and the color of the faceplates. It's worth $50 of anybody's money. SteveLincoln SA200 (1966 Redface)Lincoln IdealArc 250Steve1990 Miller Dialarc 2501993 Miller Maxstar 140 STR2015 Lincoln MP2101966 Lincoln SA200 Redface
Reply:It also appears to have the undercarriage, that's worth more than  $ 50.Eventual master of the obvious, practitioner of "stream of consciousness fabrication".  P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
Reply:Yes it has the undercarriage just not the big steel wheeled tricycle like many hadSteveLincoln SA200 (1966 Redface)Lincoln IdealArc 250Steve1990 Miller Dialarc 2501993 Miller Maxstar 140 STR2015 Lincoln MP2101966 Lincoln SA200 Redface
Reply:Buy both!  Only 50 dollars for some great welders!Forney C5 Arc WelderLincoln Idealarc 250-250 Ac/Dc Arc WelderMiller Bobcat 225g PlusLincoln PowerMig 200Forney O/A Rig
Reply:If the leads are in decent working condition, they are worth the price alone."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Personally,  I'd buy it for the sheetmetal because I have an ac/dc that has a serious case of the 'uglies'.Eventual master of the obvious, practitioner of "stream of consciousness fabrication".  P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
Reply:Needs paint well worth it 6011/7018 will run fine.
GMT+8, 2026-1-3 05:11 , Processed in 0.095853 second(s), 18 queries .
