Going with Everlast PowerTig 210EXT, Any thoughts.
发表于 2021-8-31 22:04:16 | 显示全部楼层 |阅读模式
Hi AllIm new hear and too welding, I was looking into getting a multiprocess machine such as a Everlast PowerMTS unit but as I kept doing my research I'm noticing the limitations of each of the processes like the Tig process is unable to start at a lower enough current to weld thinner materials without blowing a hole in the material and they are DC only units which rules out Aluminum Tig unless you want to use a spool gun which I find undesirable so I have changed my thinking and am going to go with an AC/DC Tig machine that will do stick (this will allow me to do my outside repairs and work) 1st (will get a separate mig machine later on) and the unit I'm very interested in is the Everlast PowerTig 210EXT. The 210EXT seems to fit the bill with low current starts on AC and DC for thinner material along with a bunch of other features that I will be able to grow into, does anyone have any thoughts or experience with this unit.Thanks
Reply:Having used all the machines I mention, and being an authorized dealer,   I personally recommend the 250ex for the same money.   At your level you really won't benefit from the few extra advanced functions of the 210ext and won't miss them.  The extra 50amps will be much more useful.  In all reality the AHP 200x at less than ½ the price will probably serve your needs very well for years.   How thin do you plan to weld.   I've welded 26ga aluminum with the AHP. It just sounds like you are getting misleading info as you have no TIG Experience.   Folks are welding soda cans and razor blades with the AHP.Last edited by soutthpaw; 06-09-2016 at 08:50 AM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:SouthPaw,You are missing what he is saying.  The 210EXT has more stick capability which is a criteria.  It actually has lower amp capability than the 250EX or the ahp.  The 250EX only has 40 more amps, not 50.  The advanced pulse will compensate for the lower amps anyway in AC.  The digital control offers more precise adjustments than the ahp and wider range of adjustment for AC.  Even if he is a beginner, it allows plenty of room for him to grow.  Yes, they are about the same money roughly, but the 210 does offer much more that he can grow with.   The 250EX is not a bad choice, but the mention of the stick capability means that the 210EXT on this alone is a better choice.But the PowerMTS units don't have a problem with low amp starts as far as I am aware.  They operate down to 5 amps.When you buy a welder, you are buying a tool box full of tools.  Each tool box has different amount of tools.  Sure you can use a pair of pliers to take off a nut and may be fine with that tool box, and can get by but when you can buy a tool box full of tools with the right tool to remove the nut, why buy the other one if budget isn't the limiting factor?  I have tools in my tool box that I've only used once or twice, but they've paid for themselves when I needed them.Last edited by lugweld; 06-09-2016 at 09:22 AM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by soutthpawHaving used all the machines I mention, and being an authorized dealer,   I personally recommend the 250ex for the same money.   At your level you really won't benefit from the few extra advanced functions of the 210ext and won't miss them.  The extra 50amps will be much more useful.  In all reality the AHP 200x at less than ½ the price will probably serve your needs very well for years.   How thin do you plan to weld.   I've welded 26ga aluminum with the AHP. It just sounds like you are getting misleading info as you have no TIG Experience.   Folks are welding soda cans and razor blades with the AHP.
Reply:Buy it and weld stuff up!   1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by OscarBuy it and weld stuff up!
Reply:Originally Posted by infernostI did just that, the 210ext should be here by next Wednesday.
Reply:Where you located at? I have been trying to find a local with this to test it outTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleWhere you located at? I have been trying to find a local with this to test it out
Reply:Originally Posted by OscarIs this your first TIG?
Reply:I would have gone with a lincoln or miller. Or htpDynasty 200DX   (2014)Millermatic 211 (2015)Optrel 864   (2014)Smith Medium duty MBA 30510 (Xmas 2014)Tennsmith 16ga 4ft finger brake (2015)Trailblazer 325 EFI and excel Thermal dynamics Cutmaster 82Miller maxtron 450
Reply:Originally Posted by outdoortI would have gone with a lincoln or miller. Or htp
Reply:Originally Posted by fpsI realize its a done deal, however, the people here could help you out a lot if you could be specific in exactly what kind of welding you are interested/expecting to do. For example, there's a big difference between repair welding, new part fab/welding, high end exotic metal welding, on site welding, and production welding.I've found my nitch, and have gone through a few welders to get exactly what I want.Pete
GMT+8, 2026-1-3 05:11 , Processed in 0.071843 second(s), 18 queries .
