C25 300 cu ft cylinder price?
发表于 2021-8-31 22:04:16 | 显示全部楼层 |阅读模式
Didn't want to hi-jack the "Filling an Owned cylinder" post so I'll ask here. I have (or should say had) a personally owned 300 cf C25 cylinder that I exchanged at the local Air Gas location at a cost of $95. I felt like that was pretty high so I wanted to try another vendor next time. The problem is, I now have a cylinder that has the Air Gas label and neck ring on it. I'm guessing another vendor is not going to swap tanks with me and may not want to fill my current tank. Should I go ahead and do another exchange and Air Gas and request a tank without a neck ring on it? Any other suggestions?GraysOrnamentalIron.com
Reply:Airgas screwed ya! Good luck finding a vendor willing to dick with an Airgas owned bottle.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:That's actually not a bad price for a 300 cu. ft. bottle of C-25 at $95 since they would charge $75 to exchange a customer-owned 160 Argon if I were still going there. But Shovelon is correct about other vendors perhaps not wanting to exchange a cylinder with Airgas stamped on it. The best thing to do would be to call up the LWS and ask.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:You might try going back to Airgas and asking for your original blank neck ring bottle back. You are not the only one this has happened to. It just might float around in their system until they sell it as a "Customer Owned" bottle to someone else.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Yup airgas screwed youMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Airgas, "Screwing you is our specialty."Sent from my SCH-I605 using TapatalkRyanMiller Multimatic 200 tig/spool gun/wireless remoteMillermatic 350P, Bernard/XR Python gunsMiller Dynasty 350, Coolmate 3.5 & wireless remoteCK WF1 TIG wire feederMiller Spectrum 375 XtremeOptrel e684Miller Digital EliteMiller Weld-Mask
GMT+8, 2026-1-3 05:20 , Processed in 0.300740 second(s), 18 queries .
