What about a LN 25 or LN 25 Pro
发表于 2021-8-31 22:04:15 | 显示全部楼层 |阅读模式
I would like to hear from anyone who has run a LN 25 off a Ranger 8. Will it short arc ok?  I see on another thread there may be challenges with 035 wire. Appreciate any inputs, thanksGeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:Originally Posted by geezerI would like to hear from anyone who has run a LN 25 off a Ranger 8. Will it short arc ok?  I see on another thread there may be challenges with 035 wire. Appreciate any inputs, thanks
Reply:I don't know JACK about the LN25PROI do know that the Ranger 8 will work its @ss trying to pump out  20v on cv mode.
Reply:Go back and reread the other thread. the OP was going to use a stick welder as a power source. Connected to a CV welder the LN-25 either one will run any type and size of wire. Up to the max size it can push. Just use the right drive roll and gun.The ranger 8 will weld flux core up to 0.068. and 0.035 mig wire just fine.
Reply:Appreciate all the inputs folks, helps.  I'll keep checking on used machines and see what comes up.   Thanks again.GeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
GMT+8, 2026-1-3 05:18 , Processed in 0.121834 second(s), 18 queries .
