Can you identify this??
发表于 2021-8-31 22:04:14 | 显示全部楼层 |阅读模式
Good Morning,I am completely new here and have my first welder.I do know what it is but I am still trying to get a manual for it. I can't find it on the Lincoln site.So it is a Lincoln AC 225-s.Square body. Colour Red.Code # 331, actual plate says w.331-1W3.Single phase, 60Hz, 50A, 230V.Type K-1170Made in Canada.Does anyone know anything about these particular ones? Approximate year? Reason for the square box?Thank you all. Attached ImagesComplete Newbie just starting out.Lincoln AC 225 Stick, Used and Abused.Finding its place on a new hobby farm.
Reply:Why don't you just down load it off the Lincoln site???? Does it look like this???http://www.lincolnelectric.com/asset...ln3/imt237.pdfI got one just like only it is AC/DC. Works good, your mileage might vary.
Reply:Originally Posted by klorinthSo it is a Lincoln AC 225-s. Square body. Colour Red...Does anyone know anything about these particular ones? Approximate year? Reason for the square box?.
Reply:The square box lincoln welders were very common in Canada. Lincoln did make them in Canada. My flat top Idealarc 250 had a Made in Canada decal on it as well.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Send an email to [email protected] with your serial number and type(k 1170)and ask for info as to date of manufacture and which manual to use.She will get back to you and usually attaches the manual to her email.Be nice and you will get a quicker answerFelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Ah-ha, Felonyass Monk knows his way around! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Thank you all for the information. Very helpful!Rick, very thorough.The imt380 manual seemed to be fairly close, but I wasn't sure. I'll try to contact Cathy and see what she is able to tell me.Thank you all.Complete Newbie just starting out.Lincoln AC 225 Stick, Used and Abused.Finding its place on a new hobby farm.
GMT+8, 2026-1-3 05:11 , Processed in 0.101438 second(s), 18 queries .
